Seems like overall opinions are good for this case,
Let’s hope new items will be available soon… as I can’t bear anymore lack of enclosure and use of heatsink hack for my board
外壳是一门生意,我累计在外壳上面花费了150¥💴,
I have one too, and like it.
I see you have installed antenna connectors on the outside @devon ! That’s nice!
Where did you get those cables?
Mouser.
The bulkhead on the cables is a tight fit on the other side of the case, as the heatsink gets in the way. A cable terminated at 90 degrees would be better. Could also just modify these cables.
I have this case and while it is better than the official metal case, its not a silver bullet.
I low key wish it had direct access to the bottom of the board and I don’t know if its rigged enough to modify due to the very thin folded metal its made up from.
I’m a bit frustrated with the temperature. Using the heatsink setup gives idle temperature of ~50C (Armbian, NVME & AX210). Additionally, if the bottom part of the case were a bit taller, it would be possible to fit m2 heatsink.
Back in stock! for those like me who missed it the first time
