I’ve been trying to install OpenBSD on the Radxa Rock Pi 4B+. The eMMC on this SBC is not revomable and I got no micro SD Card. So I’ve beeen trying to install OpenBSD via the USB OTG port using this guide from Radxa and using rkdeveloptool. Since there is no official or community image of OpenBSD and I’m a noob, I tried to follow this guide on installing OpenBSD on ROCK PI 4 (relevant part starting at “Writing a miniroot image to the eMMC”). However the guide has a removable eMMC. So this is my approach:
download the official arm64 miniroot76.img
from https://cdn.openbsd.org/pub/OpenBSD/7.6/packages/aarch64/ download the dtb and u-boot-aarch64/rock-pi-4-rk3399 package (now I got the files: rk3399-rock-pi-4b-plus.dtb, idbloader.img and u-boot.itb)
Mount the first partition of miniroot76.img and cp rk3399-rock-pi-4b-plus.dtb /mnt/rockchip/ (also seperately tried out cp rk3399-rock-pi-4b-plus.dtb /mnt/ )
connect the sbc to my laptop via otg port in MASKROM
clear the eMMC:
sudo rkdeveloptool db rk3399_loader_v1.27.126.bin
sudo rkdeveloptool ef
write miniroot76.img to eMMC: sudo rkdeveloptool wl 0 /path/to/miniroot76.img
write the uboot to eMMC:
sudo rkdeveloptool wl 0x40 idbloader.img (sector 64)
sudo rkdeveloptool wl 0x4000 u-boot.itb (sector 16384)
reboot the sbc: sudo rkdeveloptool rd , there aren’t any error messages during this whole process
now I disconnect the sbc from power and my laptop and connect it to my monitor, ethernet, keyboard and when I power it on, u-boot is loading and I land i uboot but no partition / filesystem is being recognized, the only mmc dev I can select 0: mmc dev 0 and mmc part or mmc info print nothing.
trying fatload mmc 0:1 gives the error:
** No partition table - mmc 0 **
Couldn't find partition mmc 0:1
Can't set block device
Any help is much appreciated!
NOTE: I also tried to convert the miniroot76.img from DOS to GPT using gdisk and after successfully doin so and repeating the whole process it’s the same result: I’m stuck in u-boot with no partition table being recognized
