Hello everyone. I recently bought a new Zero 3w, but have not had any luck setting it up.
The first time I plugged it in, it showed up as Unknown Device #1 in Device Manager. I went through the steps to prepare the Zero (Not the Zero 3w, so I believe this may be an issue), such as installing a driver onto my computer, and attempting to rename it within Zadig to GX-CHIP & changing the driver as I was seeing in the guide, despite not having the same USB ID in the guide.
I’ve since found the proper instructions for the Zero 3w, but I am unable to complete them. When trying to apply the loader and image, it gives me the error “Creating image object failed, stop running!”.
I am using the loader from the guide, file name/path here: C:\Users\windows\Downloads\radxa-cm3-io-idbloader-g8684d740b9f.img
I am also using the image from the guide, file name / path here: C:\Users\windows\Downloads\rk356x_spl_loader_ddr1056_v1.12.109_no_check_todly .bin
I am sorry but I don’t have a zero 3W so can’t help much more. However, it seems to me that the manual might guide you (or there is a problem with it). I’m not sure what the loader does but it’s probably needed to flash the eMMC (but of course don’t flash the loader itself onto the eMMC).
I have just successfully flashed the Android image on the eMMC.
Use the rk356x_spl_loader_ddr1056_v1.10.111.bin not the recommended one. But unfortunately the Android image is old and doesn’t support the new wireless chip.
