I am using hostapd on the official Ubuntu image to use Rock Pi E as Wireless AP, however it appears that the TX Power of the RTL8821CU chip seem to be restricted to 12dBm.
I understand that the TX power is heavily regulated and depends on my country and channel but I am running it on channel 36 US and according to iw list output I am allowed 23dBm tx power, however I am unable to change the tx power using the following command,
rock@rockpie:~$ sudo iwconfig wlan0 txpower 23
Error for wireless request “Set Tx Power” (8B26) :
SET failed on device wlan0 ; Operation not permitted.
While I managed to get 434Mbps bitrate by explicitly setting ht_capab and vht_capab in hostapd config file, I am barely exceeding 60Mbps in iperf3.
igorp
October 26, 2020, 10:07am
2
Again … setting power will work on Armbian out of the box.
Does Armbian use something other than the 8821cu kernel module ? if so I can probably install that module over Ubuntu.
igorp
October 26, 2020, 2:01pm
4
You can’t install that module over “Ubuntu” since it uses completly different (better) kernel and different (better) driver.
I moved to Armbian buster today, but I am still not able to change txpower.
igorp
October 31, 2020, 7:52am
6
Try this way:
sudo iw wlan0 set txpower fixed 3000
Also hostapd that is shipped with Armbian is patched to get the most out of it.
I tried, it still stuck at 12dBm,
rock@rockpi-e:~$ sudo iw wlan0 set txpower fixed 3000
rock@rockpi-e:~$ sudo iw dev
phy#0
Interface wlan0
ifindex 4
wdev 0x1
type AP
txpower 12.00 dBm
igorp
October 31, 2020, 8:19am
8
Debugging this exceeds my reach - driver code comes from:
# Wireless drivers for Realtek 8811, 8812, 8814 and 8821 chipsets
if linux-version compare "${version}" ge 3.14 && [ "$EXTRAWIFI" == yes ]; then
# attach to specifics tag or branch
local rtl8812auver="branch:v5.6.4.2"
display_alert "Adding" "Wireless drivers for Realtek 8811, 8812, 8814 and 8821 chipsets ${rtl8812auver}" "info"
fetch_from_repo "https://github.com/aircrack-ng/rtl8812au" "rtl8812au" "${rtl8812auver}" "yes"
You might find some hints there.
linger
June 27, 2022, 1:07pm
9
do you have any ideal for this problem? I also stuck at this problem
root@rock-3a:/home/rock# sudo iw dev wlp1s0 set txpower fixed 2000
root@rock-3a:/home/rock# iw wlp1s0 info
Interface wlp1s0
ifindex 11
wdev 0x700000001
addr 80:91:33:93:4b:b5
type managed
wiphy 7
txpower 12.00 dBm
root@rock-3a:/home/rock# sudo iw dev wlp1s0 set txpower fixed 1000
Interface wlp1s0
ifindex 11
wdev 0x700000001
type managed
wiphy 7
txpower 12.00 dBm
root@rock-3a:/home/rock# sudo iwconfig wlp1s0 txpower 10dBm
SET failed on device wlp1s0 ; Operation not permitted.
root@rock-3a:/home/rock# sudo iwconfig wlp1s0 txpower 30dBm
