Hello, I am writing to ask if it is possible to connect an RFID - RC522 module to a ROCK Pi e. I am currently making the following connections
under Ubuntu 20.04.6 LTS operating system (GNU/Linux 4.4.194-21-rockchip-g12a182552739 aarch64) and with Hardware V1.2 40-pin Header General purpose input-output (GPIO) connector
MISO to SPI0_RXD, PIN 98
MOSI to SPI0_TXD, PIN 97
SCK to SPI0_CLK, PIN 96
SDA to SPIO_CSN0, PIN 104
and ulitilizing a library called Libmraa, but I have not been able to make it work at all. Therefore I am writing to know if the Rockpi e, really supports this module, or if you can give me some help to solve it. thank you very much
If you are using Debian 11, please refer to the Debian_Bullseye installation issue, and if you use Ubuntu, please refer to Ubuntu_Focal installation issue. radxa/mraa has ROCK PI E support, as you can see in its source code.
The compilation method in the tutorial only distinguishes between debian and ubuntu, because some of the packages for debian and ubuntu are different.
In general, the SDA (Serial Data Input / Output) pin of the RC522 RFID module connects to the Chip Select (CS/SS) pin on your hardware. What would be that pin on the rock pi e?
