Today morning it worked just fine, then I made this node Kubernetes master all worker nodes are connected but now I am trying to build new docker image.
I checked docker service status and I can see it as active and running but I can spot
Attempting next endpoint for pull after error: Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting fo>
`Feb 13 17:57:02 rockpix dockerd[3617628]: time="2021-02-13T17:57:02.307577505Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"`
docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2021-02-13 17:56:22 GMT; 56s ago
TriggeredBy: ● docker.socket
Docs: https://docs.docker.com
Main PID: 3617628 (dockerd)
Tasks: 36
Memory: 62.9M
CGroup: /system.slice/docker.service
└─3617628 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
Feb 13 17:56:21 rockpix dockerd[3617628]: time="2021-02-13T17:56:21.980052804Z" level=info msg="Daemon has completed initialization"
Feb 13 17:56:22 rockpix dockerd[3617628]: time="2021-02-13T17:56:22.119130391Z" level=info msg="API listen on /run/docker.sock"
Feb 13 17:56:22 rockpix systemd[1]: Started Docker Application Container Engine.
Feb 13 17:56:24 rockpix dockerd[3617628]: time="2021-02-13T17:56:24.901387482Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Feb 13 17:56:34 rockpix dockerd[3617628]: time="2021-02-13T17:56:34.137857176Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Feb 13 17:56:36 rockpix dockerd[3617628]: time="2021-02-13T17:56:36.827323757Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
Feb 13 17:56:46 rockpix dockerd[3617628]: time="2021-02-13T17:56:46.426558192Z" level=warning msg="Error getting v2 registry: Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting for connection (Cli>
Feb 13 17:56:46 rockpix dockerd[3617628]: time="2021-02-13T17:56:46.426883781Z" level=info msg="Attempting next endpoint for pull after error: Get https://registry-1.docker.io/v2/: net/http: request canceled while waiting fo>
Feb 13 17:57:03 rockpix dockerd[3617628]: time="2021-02-13T17:57:03.407241929Z" level=info msg="ignoring event" module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
