Unable to activate the Radxa Zero 3W NPU
Hi @Spooky
Im Unable to activate the NPU in the Radxa zero 3W.I followed the documentation it says we need to activate the NPU using the “rsetup” but in my case “rsetup” command is not found.So i followed the github “https://github.com/radxa-pkg/rsetup/” but getting some dependencies issue.
Commands executed:
sudo dmesg | grep rknpu ===> No output
sudo rsetup ===> Command not found
Radxa ZERO 3W configuration:
Quad-core Arm cortex-A55 @1.6GJ+Hz
Arm Mali G52-2EE GPU
Ubuntu-22.04 server
Thanks & Regards,
ITO_Xactai
rsetup is a tool found on the Radxa Debian OS.
It is not supported by Joshua Riek’s Ubuntu versions.
To activate the NPU, please follow the guide: https://github.com/Qengineering/Radxa-Zero-3-NPU-Ubuntu22/wiki
