Greetings,
I have a Radxa CM5 SOM module, and I was trying to flash into its eMMC using the Raspberry Pi cm4 IO board. While I was able to flash into it earlier, now I am facing issues out of the blue!
When put in Maskrom mode the command
OptiPlex-7060:/media/rockchip$ sudo rkdeveloptool ld
retuns :
DevNo=1 Vid=0x2207,Pid=0x350b,LocationID=101 Maskrom
The device is getting detected!
But when I try to perform any actions related to eMMC it fails to respond to any of the following commands:
OptiPlex-7060:/media/rockchip$ sudo rkdeveloptool td
Test Device failed!
OptiPlex-7060:/media/rockchip$ sudo rkdeveloptool rid
Reading flash ID failed!
OptiPlex-7060:/media/rockchip$ sudo rkdeveloptool rfi
Read Flash Info failed!
OptiPlex-7060:/media/rockchip$ sudo rkdeveloptool rci
Read Chip Info failed!
OptiPlex-7060:/media/rockchip$ sudo rkdeveloptool rcb
Read capability Fail!
OptiPlex-7060:/media/rockchip$ sudo rkdeveloptool ef
Starting to erase flash…
Getting flash info from device failed!
Last OS I flashed into it is Ubuntu 22.04 from here.
The board boots fine and I am able to use it normally. But I am unable to flash into its eMMC with a different OS in Maskrom mode out of nowhere.
Any help is appreciated, need help debugging the issue.
Regards,
kshitij
