Ubuntu server reboot error
I have followed instructs on
https://wiki.radxa.com/Rockpi4/radxa-apt
to update kernel and uboot.
U-Boot 2017.09-02085-g5a6ae1d (Dec 04 2018 - 19:32:10 +0800)
Model: Rockchip RK3399 Evaluation Board
DRAM: 3.9 GiB
Relocation Offset is: f5c09000
PMIC: RK808
pwm-regulator(vdd-center): init 950000 uV
vdd_center 950000 uV
regulator(vdd-center) init 950000 uV
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
Using default environment
Warn: can’t find connect driver
Failed to found available display route
In: serial
Out: serial
Err: serial
rkparm_init_param_from_storage param read fail
RKPARM: Invalid parameter part table
switch to partitions #0, OK
mmc1 is current device
do_rkimg_test fail to read data from IDB
mmc_init: -95, time 26
Unknown command ‘rknand’ - try ‘help’
Unknown command ‘rksfc’ - try ‘help’
mmc_init: -95, time 18
rockchip_get_boot_mode: dev_desc is NULL!
Net: eth0: ethernet@fe300000
** No partition table - mmc 1 **
mmc_init: -95, time 19
starting USB…
USB0: USB EHCI 1.00
USB1: USB OHCI 1.0
USB2: USB EHCI 1.00
USB3: USB OHCI 1.0
USB4: Can’t get the usbphy register address
probe failed, error -6
USB5: Can’t get the usbphy register address
scanning bus 0 for devices… 1 USB Device(s) found
scanning bus 1 for devices… 1 USB Device(s) found
scanning bus 2 for devices… 1 USB Device(s) found
scanning bus 3 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
Device 0: unknown device
DMA reset timeout
Retrieving file: pxelinux.cfg/01-46-2d-b5-1d-e1-c4
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
Retrieving file: pxelinux.cfg/default-arm-rockchip
DMA reset timeout
DMA reset timeout
DMA reset timeout
Config file not found
DMA reset timeout
DMA reset timeout
Could not get mmc 0
do_boot_rockchip: dev_desc is NULL!
Install the latest ubuntu server image.
When
sudo reboot
it always fail to reboot.
Have to re-plug power cable.
Normal boot logs
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
do_rkimg_test found IDB in SDcard
Boot from SDcard
get part misc fail -1
Scanning mmc 1:4…
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
629 bytes read in 4 ms (153.3 KiB/s)
select kernel
1:      kernel-4.4.154-60-rockchip-g3706e8d27542
2:      kernel-4.4.154-59-rockchip-g5e70f14
Enter choice: 1:        kernel-4.4.154-60-rockchip-g3706e8d27542
Retrieving file: /vmlinuz-4.4.154-60-rockchip-g3706e8d27542
reading /vmlinuz-4.4.154-60-rockchip-g3706e8d27542
20006920 bytes read in 854 ms (22.3 MiB/s)
append: earlyprintk console=ttyFIQ0,1500000n8 rw init=/sbin/init root=PARTUUID=b921b045-1d rootwait rootfstype=ext4
Retrieving file: /dtbs/4.4.154-60-rockchip-g3706e8d27542/rockchip/rockpi-4b-linux.dtb
reading /dtbs/4.4.154-60-rockchip-g3706e8d27542/rockchip/rockpi-4b-linux.dtb
96440 bytes read in 15 ms (6.1 MiB/s)
Flattened Device Tree blob at 01f00000
  Booting using the fdt blob at 0x1f00000
  Loading Device Tree to 00000000f3dd5000, end 00000000f3def8b7 … OK
Adding bank: start=0x00200000, size=0xf7e00000
Starting kernel …
root@rockpi4:~# sudo reboot
[  OK  ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
        Stopping Network Manager Script Dispatcher Service…
        Stopping Hostname Service…
[  OK  ] Stopped target Sound Card.
[  OK  ] Stopped target Timers.
[  OK  ] Stopped Daily Cleanup of Temporary Directories.
[  OK  ] Stopped Discard unused blocks once a week.
[  OK  ] Stopped Message of the Day.
        Stopping Session 1 of user root.
[  OK  ] Stopped Daily apt upgrade and clean activities.
[  OK  ] Stopped Daily apt download activities.
[  OK  ] Stopped target System Time Synchronized.
[  OK  ] Stopped target Host and Network Name Lookups.
        Stopping User Manager for UID 0…
        Stopping Authorization Manager…
[  OK  ] Stopped Stop ureadahead data collection 45s after completed startup.
[  OK  ] Stopped target Graphical Interface.
        Stopping Accounts Service…
[  OK  ] Stopped target Multi-User System.
[  OK  ] Stopped target Login Prompts.
        Stopping Serial Getty on ttyFIQ0…
        Stopping Getty on tty1…
        Stopping Regular background program processing daemon…
        Stopping System Logging Service…
[  OK  ] Stopped Wait until snapd is fully seeded.
        Stopping Snappy daemon…
        Stopping Dispatcher daemon for systemd-networkd…
        Stopping OpenBSD Secure Shell server…
        Stopping irqbalance daemon…
        Stopping Modem Manager…
[  OK  ] Stopped Regular background program processing daemon.
[  OK  ] Stopped Accounts Service.
[  OK  ] Stopped irqbalance daemon.
[  OK  ] Stopped Dispatcher daemon for systemd-networkd.
[  OK  ] Stopped Snappy daemon.
[  OK  ] Stopped Authorization Manager.
[  OK  ] Stopped Modem Manager.
[  OK  ] Stopped Hostname Service.
[  OK  ] Stopped Network Manager Script Dispatcher Service.
[  OK  ] Stopped Serial Getty on ttyFIQ0.
[  OK  ] Stopped Getty on tty1.
[  OK  ] Stopped System Logging Service.
[  OK  ] Stopped OpenBSD Secure Shell server.
[  OK  ] Stopped User Manager for UID 0.
[  OK  ] Stopped Session 1 of user root.
[  OK  ] Removed slice User Slice of root.
        Stopping Login Service…
[  OK  ] Removed slice system-getty.slice.
[  OK  ] Removed slice system-serial\x2dgetty.slice.
        Stopping Permit User Sessions…
        Unmounting Mount unit for core, revision 6209…
        Unmounting Mount unit for core, revision 6204…
        Unmounting Mount unit for core, revision 6216…
[  OK  ] Stopped Permit User Sessions.
[  OK  ] Stopped target Remote File Systems.
[  OK  ] Stopped target Network.
        Stopping Network Manager…
        Stopping WPA supplicant…
        Stopping Network Name Resolution…
[  OK  ] Stopped Network Name Resolution.
[  OK  ] Unmounted Mount unit for core, revision 6204.
[  OK  ] Unmounted Mount unit for core, revision 6209.
[  OK  ] Stopped Login Service.
[  OK  ] Stopped target User and Group Name Lookups.
[  OK  ] Unmounted Mount unit for core, revision 6216.
[  OK  ] Stopped WPA supplicant.
[  OK  ] Stopped Network Manager.
        Stopping D-Bus System Message Bus…
[  OK  ] Stopped D-Bus System Message Bus.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target Paths.
[  OK  ] Stopped target Sockets.
[  OK  ] Closed Syslog Socket.
[  OK  ] Closed Socket activation for snappy daemon.
[  OK  ] Closed UUID daemon activation socket.
[  OK  ] Stopped target Slices.
[  OK  ] Removed slice User and Session Slice.
[  OK  ] Closed D-Bus System Message Bus Socket.
[  OK  ] Stopped target System Initialization.
        Stopping Network Time Synchronization…
        Stopping Update UTMP about System Boot/Shutdown…
        Stopping Load/Save Random Seed…
[  OK  ] Stopped target Local Encrypted Volumes.
[  OK  ] Stopped Dispatch Password Requests to Console Directory Watch.
[  OK  ] Stopped Forward Password Requests to Wall Directory Watch.
[  OK  ] Stopped Apply Kernel Variables.
[  OK  ] Stopped Load Kernel Modules.
[  OK  ] Stopped Network Time Synchronization.
[  OK  ] Stopped Update UTMP about System Boot/Shutdown.
[  OK  ] Stopped Load/Save Random Seed.
[  OK  ] Stopped Create Volatile Files and Directories.
[  OK  ] Stopped target Local File Systems.
        Unmounting /run/user/0…
        Unmounting /boot…
[  OK  ] Unmounted /run/user/0.
[  OK  ] Stopped target Swap.
[  OK  ] Unmounted /boot.
[  OK  ] Reached target Unmount All Filesystems.
[  OK  ] Stopped File System Check on /dev/mmcblk0p4.
[  OK  ] Removed slice system-systemd\x2dfsck.slice.
[  OK  ] Stopped target Local File Systems (Pre).
[  OK  ] Stopped Remount Root and Kernel File Systems.
[  OK  ] Stopped Create Static Device Nodes in /dev.
[  OK  ] Reached target Shutdown.
[  OK  ] Reached target Final Step.
        Starting Reboot…
[   19.978684] dw_wdt: unexpected close, system will reboot soon
[   20.711189] reboot: Restarting system
DDR Version 1.14 20180803
In
soft reset
SRX
Channel 0: LPDDR4,50MHz
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,50MHz
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
256B stride
channel 0
CS = 0
MR0=0x98
MR4=0x82
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x82
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x98
MR4=0x82
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
CS = 1
MR0=0x18
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
change freq to 800MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
OUT
Boot1: 2018-08-06, version: 1.15
CPUId = 0x0
ChipType = 0x10, 277
mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
mmc: ERROR: Card did not respond to voltage select!
emmc reinit
emmc reinit
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=122112MB
FwPartOffset=2000 , 0
StorageInit ok = 56809
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
GPT 0x3190d20 signature is wrong
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xc4d50
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):56eea3d
NOTICE:  BL31: Built : 15:27:37, Aug  8 2018
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1151): pd status 3e
INFO:    BL31: Initializing runtime services
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
starting USB…
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
DMA reset timeout
It can’t recover by typing ‘reset’ uboot command.
Must re-plug power.
=> mmc info
Device: dwmmc@fe320000
Manufacturer ID: 1b
OEM: 534d
Timing Interface: Legacy
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 119.3 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
@jack Do you have old version uboot image?
ChipType = 0x10, 276
emmc reinit
emmc reinit
SdmmcInit=2 1
This is a new Samsung U3 128G micro SD card.
Try to re-plug micro SD card.
And ‘run boot_scripts’ in uboot,
still fail.
It’s not the defect of my SD card. it’s a bug of uboot.
