The ubuntu image shared on the main site does not use the login “rock” or “radxa” despite what the wiki says. Any pointers here would be appreciated.
the default account should be rock / rock,can you share the image link ?
https://github.com/radxa-build/rock-5b/releases/download/b33/rock-5b_ubuntu_jammy_kde_b33.img.xz
I tried both SSH and Desktop login and it “rock” “rock” did not work
I used this image, and the debian the other day. rock/rock worked on both?
I used the debian one the other day and I was able to get in with rock just fine. Not sure what is going on with this one.
did you change the password yourself? or re-flash the image to check again?
No i flashed the image and now I can’t do anything since I can’t log in, I bought a usb to nvme adapter so I can inspect the drive to see what happened
looks like something glitched out, there is no sign of rock or radxa in the passwd or shadow files.
Hi,I have the same problem. Have you solved your problem?
Its radxa radxa… 🤦😂
