I would like to switch to the native udev:armhf package on the Ubuntu image. (This is a requirement for Openhab to run properly) But the service is not starting up after the switch. This is the output from the installation:
rock@openhabianpi:~$ sudo apt-get install udev:armhf
[sudo] password for rock:
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
libacl1:armhf libattr1:armhf libblkid1:armhf libkmod2:armhf libpcre3:armhf libselinux1:armhf libudev1:armhf libuuid1:armhf uuid-runtime
The following packages will be REMOVED:
udev
The following NEW packages will be installed:
libacl1:armhf libattr1:armhf libblkid1:armhf libkmod2:armhf libpcre3:armhf libselinux1:armhf libudev1:armhf libuuid1:armhf udev:armhf uuid-runtime
0 upgraded, 10 newly installed, 1 to remove and 0 not upgraded.
Need to get 1611 kB of archives.
After this operation, 1220 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libattr1 armhf 1:2.4.47-2build1 [8312 B]
Get:2 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libacl1 armhf 2.2.52-3build1 [13.7 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libuuid1 armhf 2.31.1-0.4ubuntu3.3 [19.5 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libblkid1 armhf 2.31.1-0.4ubuntu3.3 [112 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libkmod2 armhf 24-1ubuntu3.2 [34.3 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libpcre3 armhf 2:8.39-9 [209 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports bionic/main armhf libselinux1 armhf 2.7-2build2 [58.9 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf libudev1 armhf 237-3ubuntu10.15 [48.8 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main armhf udev armhf 237-3ubuntu10.15 [1075 kB]
Get:10 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 uuid-runtime arm64 2.31.1-0.4ubuntu3.3 [31.8 kB]
Fetched 1611 kB in 0s (3285 kB/s)
debconf: unable to initialize frontend: Dialog
debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 76, <> line 10.)
debconf: falling back to frontend: Readline
Selecting previously unselected package libattr1:armhf.
(Reading database ... 31118 files and directories currently installed.)
Preparing to unpack .../0-libattr1_1%3a2.4.47-2build1_armhf.deb ...
Unpacking libattr1:armhf (1:2.4.47-2build1) ...
Selecting previously unselected package libacl1:armhf.
Preparing to unpack .../1-libacl1_2.2.52-3build1_armhf.deb ...
Unpacking libacl1:armhf (2.2.52-3build1) ...
Selecting previously unselected package libuuid1:armhf.
Preparing to unpack .../2-libuuid1_2.31.1-0.4ubuntu3.3_armhf.deb ...
Unpacking libuuid1:armhf (2.31.1-0.4ubuntu3.3) ...
Selecting previously unselected package libblkid1:armhf.
Preparing to unpack .../3-libblkid1_2.31.1-0.4ubuntu3.3_armhf.deb ...
Unpacking libblkid1:armhf (2.31.1-0.4ubuntu3.3) ...
Selecting previously unselected package libkmod2:armhf.
Preparing to unpack .../4-libkmod2_24-1ubuntu3.2_armhf.deb ...
Unpacking libkmod2:armhf (24-1ubuntu3.2) ...
Selecting previously unselected package libpcre3:armhf.
Preparing to unpack .../5-libpcre3_2%3a8.39-9_armhf.deb ...
Unpacking libpcre3:armhf (2:8.39-9) ...
Selecting previously unselected package libselinux1:armhf.
Preparing to unpack .../6-libselinux1_2.7-2build2_armhf.deb ...
Unpacking libselinux1:armhf (2.7-2build2) ...
Selecting previously unselected package libudev1:armhf.
Preparing to unpack .../7-libudev1_237-3ubuntu10.15_armhf.deb ...
Unpacking libudev1:armhf (237-3ubuntu10.15) ...
Selecting previously unselected package udev:armhf.
Preparing to unpack .../8-udev_237-3ubuntu10.15_armhf.deb ...
Unpacking udev:armhf (237-3ubuntu10.15) over (237-3ubuntu10.15) ...
Selecting previously unselected package uuid-runtime.
Preparing to unpack .../9-uuid-runtime_2.31.1-0.4ubuntu3.3_arm64.deb ...
Unpacking uuid-runtime (2.31.1-0.4ubuntu3.3) ...
Setting up libudev1:armhf (237-3ubuntu10.15) ...
Setting up libattr1:armhf (1:2.4.47-2build1) ...
Setting up libuuid1:armhf (2.31.1-0.4ubuntu3.3) ...
Setting up libpcre3:armhf (2:8.39-9) ...
Setting up libkmod2:armhf (24-1ubuntu3.2) ...
Setting up libblkid1:armhf (2.31.1-0.4ubuntu3.3) ...
Setting up uuid-runtime (2.31.1-0.4ubuntu3.3) ...
Adding group `uuidd' (GID 114) ...
Done.
Warning: The home dir /run/uuidd you specified can't be accessed: No such file or directory
Adding system user `uuidd' (UID 109) ...
Adding new user `uuidd' (UID 109) with group `uuidd' ...
Not creating home directory `/run/uuidd'.
Created symlink /etc/systemd/system/sockets.target.wants/uuidd.socket → /lib/systemd/system/uuidd.socket.
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Setting up libselinux1:armhf (2.7-2build2) ...
Processing triggers for systemd (237-3ubuntu10.15) ...
Setting up libacl1:armhf (2.2.52-3build1) ...
Setting up udev:armhf (237-3ubuntu10.15) ...
Job for systemd-udevd.service failed because a fatal signal was delivered to the control process.
See "systemctl status systemd-udevd.service" and "journalctl -xe" for details.
invoke-rc.d: initscript udev, action "restart" failed.
● systemd-udevd.service - udev Kernel Device Manager
Loaded: loaded (/lib/systemd/system/systemd-udevd.service; static; vendor preset: enabled)
Active: activating (start) since Sat 2019-03-23 12:49:23 CET; 19ms ago
Docs: man:systemd-udevd.service(8)
man:udev(7)
Main PID: 17256 (systemd-udevd)
Tasks: 1
CGroup: /system.slice/systemd-udevd.service
└─17256 [systemd-udevd]
Mar 23 12:49:23 openhabianpi systemd[1]: Starting udev Kernel Device Manager...
Mar 23 12:49:23 openhabianpi systemd[1]: systemd-udevd.service: Main process exited, code=killed, status=31/SYS
Mar 23 12:49:23 openhabianpi systemd[1]: systemd-udevd.service: Failed with result 'signal'.
Mar 23 12:49:23 openhabianpi systemd[1]: Failed to start udev Kernel Device Manager.
Mar 23 12:49:23 openhabianpi systemd[1]: systemd-udevd.service: Service has no hold-off time, scheduling restart.
Mar 23 12:49:23 openhabianpi systemd[1]: systemd-udevd.service: Scheduled restart job, restart counter is at 2.
Mar 23 12:49:23 openhabianpi systemd[1]: Stopped udev Kernel Device Manager.
Mar 23 12:49:23 openhabianpi systemd[1]: systemd-udevd.service: Scheduled restart job, restart counter is at 3.
dpkg: error processing package udev:armhf (--configure):
installed udev:armhf package post-installation script subprocess returned error exit status 1
udev:armhf
And this is the output from systemctl status systemd-udevd.service:
Active: failed (Result: signal) since Sat 2019-03-23 12:56:42 CET; 1min 5s ago
man:udev(7)
Process: 17456 ExecStart=/lib/systemd/systemd-udevd (code=killed, signal=SYS)
Main PID: 17456 (code=killed, signal=SYS)
But if I run sudo /lib/systemd/systemd-udevd I get no errors. Any ideas what could cause this problem? By the way, on the debian image the udev:armhf package seems to be installed by default.
