Ubuntu 26.04.1 LTS images for the Radxa Dragon Q6A, now on Linux 7.2.9 (HDMI works, Wi-Fi/BT/audio/NPU, apt upgrade safe)
I’ve published v1.3.0 of my custom Ubuntu 26.04.1 LTS images (Server and Desktop/GNOME) for the Radxa Dragon Q6A (QCS6490). They exist because on this board the stock image has had two annoying problems for me: HDMI dying after an apt upgrade, and no working audio.
What’s new in v1.3.0: kernel 6.18.2 → 7.2.9
I’m using the Armbian edge branch for this board, pinned to the v7.2.9 tag. Earlier I had tried 7.0 and 7.2.3 and both broke HDMI on my board (same symptom other people reported on the Radxa forum). With 7.2.9 plus the DisplayPort/DPU patches Armbian carries for the QCS6490, HDMI works. Subjectively it also feels more stable and faster than 6.18.2 here, but that’s one person’s impression, not a benchmark.
If you prefer the older kernel, you can still build with 6.18.2 (KERNEL_BRANCH=current scripts/build.sh) or use the v1.2.1 images.
What I tested on real hardware (one board, mine)
| | Desktop | Server |
| Boots from native NVMe slot | yes | not tested (booted from a SATA SSD in a USB case) |
| Boots from USB (NVMe/SATA in a USB case) | yes | yes |
| HDMI | yes | yes (console) |
| Wi-Fi + Bluetooth (onboard, aic8800) | yes | yes |
| Audio (headphones + HDMI) | yes | sound card shows up; I did not listen to it |
| NPU device nodes (/dev/fastrpc-*, adsp/cdsp running) | yes | nodes present, user in fastrpc group |
| apt update && apt upgrade, then reboot | yes | yes |
Desktop extras: GNOME (ubuntu-desktop-minimal, no office suite or games), native Firefox from Mozilla’s apt repo (no snap), and the classic GNOME Software.
Known issues / honest caveats
  • Headphones: once, after a boot, only the right channel played until I re-plugged the jack (jack detection said “off”). Re-plugging fixed it. I couldn’t reproduce it yet, so the root cause isn’t confirmed.
  • The GNOME “Software Updater” sometimes looped on the same update in an earlier build. I traced that to Ubuntu’s Firefox transition package replacing the native Firefox via unattended-upgrades; the v1.3.0 images block that with an apt pin, and the loop is gone in my testing.
  • dmesg shows some audio/SoundWire/DSP errors (qcom-apm CMD timeout, port mismatch). They don’t affect the audio I tested.
  • GNOME Resources shows the CPU as just “Cortex-A55”, most GPU fields as N/D, and has no NPU page. That’s how the app (and upstream Linux) exposes this hardware. GNOME Settings > About shows 4x A78 + 4x A55 and the Adreno FD643 correctly.
  • Converting your own AI models still needs the Qualcomm QAIRT SDK (free, account required). The runtime and device access are included.
  • Only tested by me, on one board. Feedback from other Q6A owners would be very welcome.
Download / install
Release: Release Ubuntu 26.04.1 LTS "Resolute Raccoon" for the Radxa Dragon Q6A — v1.3.0 (Linux 7.2.9) · rafaelwms/ubuntu-26.04.1-dragon-q6a · GitHub
Images are split into ~1.5 GB parts for GitHub’s asset limit. The easiest way is the interactive installer in the repo (it downloads the parts, verifies SHA256, reassembles and flashes, asking you to confirm the target disk):
git clone https://github.com/rafaelwms/ubuntu-26.04.1-dragon-q6a.git
cd ubuntu-26.04.1-dragon-q6a
./install.sh # Linux
./install_mac.sh # macOS (I have not run this one on a Mac myself)
Default login is radxa / radxa — change the password on first boot. The root partition grows to fill the disk on first boot.
The README and docs/pesquisa.md (in Portuguese) document the root causes and every dead end along the way.
Repo: GitHub - rafaelwms/ubuntu-26.04.1-dragon-q6a · GitHub
Hey, amazing work on getting this running so smoothly! I had a couple of quick questions based on your post:
  1. Performance: You mentioned it feels “faster” than 6.18.2. Could you clarify what that refers to? Is it shorter boot times, a snappier UI, or better overall system responsiveness?
  2. Future Releases: Do you have any plans to test or support Ubuntu 26.10?
  3. Future Roadmap: Are there any plans on further improving NPU support, mainline kernel integration, or adding other desktop environments?
Thanks again for your hard work and detailed testing!
Hello!
Thank you for appreciating the work done for the Radxa Q6A. Well, I happen to have a unit and wanted to explore its full potential; since I’m doing that anyway, it’s a pleasure to be able to share my findings and be of help.
Let answer yours questions:
  • Performance: You mentioned it feels “faster” than 6.18.2. Could you clarify what that refers to? Is it shorter boot times, a snappier UI, or better overall system responsiveness?
    • By “fastest,” I mean in the most comprehensive sense. It’s quite responsive, and I also found the usability to be “smoother”—if that term fits well here. In any case, once I switched to Kernel 7.2.9-edge, everything started working better.
  • Future Releases: Do you have any plans to test or support Ubuntu 26.10?
    • Yes. Actually, I’m replying to you from my Radxa device, running Ubuntu 26.10. I’m even more pleased with the result. You can consider this an additional point to what I mentioned in my previous answer. My only regret is that this version isn’t an LTS (Long-Term Support) release. I’ll be launching it soon; it’s currently in the user-testing phase.
  • Future Roadmap: Are there any plans on further improving NPU support, mainline kernel integration, or adding other desktop environments?
    • As for the NPU, if there are any updates, we will include them in future releases. I ensure that it remains functional, but I do not expand its capabilities.
    Best Regards from Brazil!
    Rafael WMS
Hello Rafael, Looks nice! May I ask which firmware you did use, did you use the latest dragon-q6a_flat_build_wp_260916 ?
I did install bios version 260916, and the Ubuntu version seems to be working! thanx!
Hi Rafael, thanks for your work! I managed to get the npu working fine with your distro, you can check all the process to get it working in my repo.
