Hi all,
I am running Ubuntu Server 24.04 on a Radxa X4 with 32gb of eMMC. After a few days the device would lockup with an error that the file system is in read only mode. When looking at the logs The kernel logs are littered with “mmc0: running CQE recovery”. It appears there is some issue with the eMMC support in Ubuntu with regards to NCQ.
I am posting this here incase anyone experiences the same issue. As a work around I was able to fix this using the following to disable the CQE:
edit /etc/default/grub
sudo nano /etc/default/grub -
Find the line “GRUB_CMDLINE_LINUX_DEFAULT” and insert “sdhci.debug_quirks=0x20000” in the “”. Do not remove anything already there.
GRUB_CMDLINE_LINUX_DEFAULT="sdhci.debug_quirks=0x20000"or
GRUB_CMDLINE_LINUX_DEFAULT="sdhci.debug_quirks=0x20000 some.exsting=commands" -
Update Grub
sudo update-grub -
Reboot
This should take care of the eMMC errors but it is only a work around and not a fix.
