I built a system that uses both UART1 and UART2 for remote control and troubleshooting of devices. The entire system works fine except that I can’t boot the Rock Pi E with a 40 cm cable plugged into UART2 (only connect to GND, Tx, Rx on the RockPiE; the other end of the cable is floating).
I did some troubleshooting and I suspect that since UART2 is also used in the bootloader to interupt the boot process, I suspect that this floating Tx cable causes issues and interrupts the boot process.
I tried changing the bootdelay to 0 using
setenv bootdelay 0
saveenv
But I get an error that the MMC didn’t respond to voltage change command.
So… is there another way to modify this bootdelay to try to see if it resolves my issue?
I connected a console to the Tx pin and Gnd only while leaving my floating cable on the Rx pin. This way, I was able to confirm what happens, the bootloader gets interupted during the boot process.
Is there a way to disable the U-boot UART? I tried rebuilding u-boot by setting “CONFIG_DEBUG_UART=n” in rock-pi-e-rk3328_defconfig but that didn’t seem to work.
I will leave it here as it may help someone else but I answered myself.
By setting the bootdelay to “-2”, interupting u-boot is disabled so the board boots correctly. It still requires rebuilding u-boot from source to make this change but it’s at least feasible.
~/rockchip-bsp$ grep BOOTDELAY u-boot/configs/rock-pi-e-rk3328_defconfig
CONFIG_BOOTDELAY=-2
If you see the U-Boot boot log, you will find that bootloader can be stopped by hitting any key.
You have mentioned that a 40 cm cable. And you suspect that the floating Tx cable interrupts the boot process. What does it look like?
The problem is when there is a floating cable on Rx.
I was able to see it by connecting a console to TX and GND only. That way I saw the regular output and the bootloader being interrupted by some random characters appearing. By setting the boots slay to -2, it prevents interrupting u-boot and all is good.
In my scenario I had a floating cable on UART2, acting a bit like an antenna but the same problem would occur if UART2 was connected to a peripheral always transmitting, a GPS for example. In that case, rebooting the Rock Pi E would stop the bootloader from proceeding.
I had the same issue on Rasperry Pi and I managed to rebuild the u-boot and copy the .bin file to the boot partition on the SD card. Now I have a Rock Pi and I want to do the same steps but I noticed that there is no .bin file.
You mentioned that after changing the config file and setting the bootdelay to -2, we must rebuild the u-boot from source. Can you show how this could be done ?
Thank you
I have the same problem. By having TX connected(from computer perspective) the board does not even boot. Maybe I should mention, I am using Radxa Zero. Also I noticed that boot process is sometimes interrupted, without having connected TX cable. It looks like that cable connected just to RX is causing some issues.
So, I guess only workaround is to use “-2”. I would really like to have permanently connected RX and TX, to troubleshoot any boot issues. But this seems to be unfeasible.
