I have several Rock 5B boards, and I am investigating a low-latency audio application on it using Android (Vulkan is a must).
This app uses opensl as the sound output API, and opensl won’t do anything with custom audio buffer sizes set from the apps.
I know that, for other Android platforms, it’s possible to tweak the Android audio buffer size by editing system files, like for example /vendor/etc/audio_pcm.xml
Sadly, /vendor/etc/audio_pcm.xml is absent from the Rock 5B Android disribution.
So, how can the audio buffer size be edited/changed in the Rock 5B Android distribution?
It’s currently set to 480 block frames, apparently, and it should be possible to change it.
