I use ROCK Pi 4B v1.3, with Debian9Desktop from Radxa download. Kernel 4.4.154-90.
I want to use it as external USB storage for my PC.
And I’d like to have default set of ROCK Pi 4 USB OTG port as a g_mass_storage device.
I observed that behavior of ROCK Pi 4 as g_mass_storage device depends on the connection to Host PC before I power the ROCK PI 4.
If I first power up the ROCK pi 4 and later connect to host PC, to start the OTG I need to toggle the switch in the way @antihacker do.
If I first connect USB port to host PC, set the DEVICE position of the switch and later power up the ROCK Pi 4. The OTG is working properly. I do not need to toggle the OTG switch.
Is there a way to start the ROCK Pi 4 always as the OTG device?
I checked your suggestion, but it doesn’t work in the way I need.
I changed rockpi-4b-linux.dts
dr_mode I found in line 473 (usb0 → dwc3@fe800000 → dr_mode)
I discovered that only one change between both settings (otg/peripheral) is the reaction for switching to the HOST position:
when dr_mode = “peripheral”;
the Host is not starting and the only log message is that rockchip-dwc3 usb0: USB unconnected.
[ 67.561442] rockchip-dwc3 usb0: Peripheral disconnect timeout
[ 67.561974] rockchip-dwc3 usb0: USB unconnected
when dr_mode = “otg” the Host is starting.
[10374.670799] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[10374.671976] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 7
[10374.672887] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[10374.673953] xhci-hcd xhci-hcd.8.auto: irq 231, io mem 0xfe800000
[10374.676352] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[10374.676967] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[10374.677732] usb usb7: Product: xHCI Host Controller
[10374.678183] usb usb7: Manufacturer: Linux 4.4.154-90-rockchip-ga14f6502e045 xhci-hcd
[10374.678870] usb usb7: SerialNumber: xhci-hcd.8.auto
[10374.680579] hub 7-0:1.0: USB hub found
[10374.680982] hub 7-0:1.0: 1 port detected
[10374.682105] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[10374.683056] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 8
[10374.683862] usb usb8: We don’t know the algorithms for LPM for this host, disabling LPM.
[10374.684771] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003
[10374.685488] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[10374.686143] usb usb8: Product: xHCI Host Controller
[10374.686598] usb usb8: Manufacturer: Linux 4.4.154-90-rockchip-ga14f6502e045 xhci-hcd
[10374.687286] usb usb8: SerialNumber: xhci-hcd.8.auto
[10374.693202] hub 8-0:1.0: USB hub found
[10374.693609] hub 8-0:1.0: 1 port detected
[10374.694566] rockchip-dwc3 usb0: USB HOST connected
Switching back to the DEVICE position, starts the g_mass_storage and RockPi is visible as a Mass storage Device from the Host PC.
dmesg of RockPi:
[ 154.074280] phy phy-ff770000.syscon:[email protected]: charger = USB_SDP_CHARGER
[ 154.074940] rockchip-dwc3 usb0: USB peripheral connected
[ 154.394231] g_mass_storage gadget: high-speed config #1: Linux File-Backed Storage
So, maybe there is other tip I can check ?
