I have been trying to boot from micro SD (Sandisk Ultra 128GB) with no luck.
I used balenaEtcher to write the Ubuntu server 18.04 image on the SD, but it cannot get to the login prompt. HDMI has a signal though.
This is how the file system looks like. I used micro SD to USB converter.
Any idea?
Thx!
Update 1:
Debian can boot fine. What’s wrong with the Ubuntu server?
Update 2:
Manjaro and Android 9 work too, but Armbian does not boot.
igorp
April 4, 2020, 7:51am
2
Official Armbian boots fine. (with updated SPI boot loader ofc)
Which image do you use ?
Check those posts:
As the title, I successfully flashed my spi flash according to Radxa official course but my board could not boot. I found when I inserted the SDcard and connected the nvme disk which both was flashed lastly Armbian buster image, my board can boot and...
Is this still the correct patch for u-boot to enable USB booting first?
I already added it to Android firmware but USB booting didn’t work.
I wonder what is different with Armbian u-boot that it allows USB booting correctly?
I didn’t do anything with SPI, must I overwrite, dd it with zero’s?
My wish is perhaps for Radxa to help so that I can make an Android - LibreELEC(or Armbian) dual-boot firmware both run from emmc or SD storage with a menu in Android to boot to LE and in LE a menu to…
