Trouble with audio recording
Hi everyone,
I’m currently struggling on recording from the audio jack, which should be possible, no?
I installed Debian and am perfectly fine playing sound files with “aplay”, but using “arecord” to capture data from my microphone just produces static noise. I’d guess that I somehow need to switch from playback to capture but after hours and days of searching the internet and trying different things, I still made no progress.
So, can anyone of you help me with that? I hope it’s a simple task, just complicated by my inexperience.
Best regards,
Tim
I would just like to also add that I’ve similarly not been able to make the microphone jack work.
Hi Tim,
same problem with me! Could you find out something?
Spec of ES8316 audio-chip says 3,3Vrms max as input. Normally, depending of Mic-Type, MicBias has to be switched on/off. It looks like it is swiched off and so you need a signal input-voltage of about 3 V for fullscale input. I couldn´t see any voltage on the Mic-Pin. I took a pre-amplifire with ~3V output and it worked.
The question to Raxda - is it that way? And if yes, how to swich MicBias on/off?
I worked around the problem by using a small USB sound card. It wouldn’t record from it at first either
because I had to switch default to it, using
“pactl” + “list short sources”,
“pactl”+“set-default-source”+“card name”
I did neither check if the default was set correctly beforehand, nor did I try it again with the onboard jack,
because now everything works just fine, the Rock is fast and competent in doing what I want it to.
Greetings
Tim
I personally use AudFree Audio Capture to do the same without any hassle.
Same here, CM3 with CM3-IO board both from Radxa - static noise when recording. Any solution ?
