Touchscreen ADS7846 driver cannot find spi3.0 bus
ADS7846 Driver error in dmesg:
Touchscreen dtbo file:
/dts-v1/;
/plugin/;
        compatible = "radxa,radxa-cm3-io", "rockchip,rk3566";
        fragment@0 {
                target = <&spi3>;
                __overlay__ {
                        #address-cells = <1>;
                        #size-cells = <0>;
                        ads7846@0 {
                                compatible = "ti,ads7846";
                                reg = <0>;
                                pinctrl-names = "default";
                                pinctrl-0 = <&spi3m0_cs0 &spi3m0_pins>;
                                spi-max-frequency = <50000000>;
                                interrupts = <255 2>;
                                interrupt-parent = <&gpio0>;
                                pendown-gpio = <&gpio0 18 0>;
                                ti,x-min = [00 00];
                                ti,y-min = [00 00];
                                ti,x-max = [0f ff];
                                ti,y-max = [0f ff];
                                ti,pressure-min = [00 00];
                                ti,pressure-max = [ff ff];
                                ti,x-plate-ohms = [01 90];
IRQ is connected to pin GPIO0_C2 (or pin 37 on 40 pin header found on CM4IO)
CS is connected to pin GPIO4_A6 (SPI3_CS0_M0, or pin 24)
Dtoverlays enabled:
my touchscreen dtbo
rk3568-spi3-m0-cs0-spidev.dtbo
