I found a way to overwrite edid by debugfs and currently see that DRM unbale to set correct clock:
[ 1485.183383] rockchip-vop2 fdd90000.vop : [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 198940000, get 198000000
[ 1485.139783] [drm:drm_detect_monitor_audio] Monitor has basic audio support
[ 1485.139805] [drm:drm_add_edid_modes] ELD monitor HP Z24n G2
[ 1485.139822] [drm:drm_add_edid_modes] HDMI : latency present 0 0, video latency 0 0, audio latency 0 0
[ 1485.139837] [drm:drm_add_edid_modes] ELD size 36, SAD count 1
[ 1485.139859] [drm:drm_add_display_info] Supported Monitor Refresh rate range is 0 Hz - 0 Hz
[ 1485.139873] [drm:drm_add_display_info] non_desktop set to 0
[ 1485.139889] [drm:drm_add_display_info] HDMI : DVI dual 0, max TMDS clock 200000 kHz
[ 1485.139905] [drm:drm_add_display_info] HDMI-A-1 : No deep color support on this HDMI sink.
[ 1485.139921] [drm:drm_add_display_info] CEA VCDB 0x2b
[ 1485.139927] [drm:drm_add_display_info] HDMI-A-1 : Assigning EDID-1.4 digital sink color depth as 0 bpc.
[ 1485.140125] rockchip-vop2 fdd90000.vop : [drm:vop2_crtc_mode_valid] vop2 clock: [198000]
[ 1485.140133] rockchip-vop2 fdd90000.vop : [drm:vop2_crtc_mode_valid] vop2 requested clock [198940]
[ 1485.140160] [drm:drm_helper_probe_single_connector_modes] [CONNECTOR:423:HDMI-A-1] probed modes :
[ 1485.140172] [drm:drm_mode_debug_printmodeline] Modeline "1440x1440" : 90 198940 1440 1490 1498 1514 1440 1448 1458 1460 0x48 0xa
[ 1485.140189] [drm:drm_mode_object_put] OBJ ID : 423 (2)
[ 1485.140208] [drm:drm_ioctl] comm="drm-event-liste" pid=375, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETCONNECTOR
[ 1485.140243] [drm:drm_mode_object_put] OBJ ID : 423 (2)
[ 1485.140261] [drm:drm_ioctl] comm="drm-event-liste" pid=375, dev=0xe200, auth=1, DRM_IOCTL_MODE_OBJ_GETPROPERTIES
[ 1485.150068] [drm:drm_mode_object_put] OBJ ID : 642 (3)
[ 1485.150121] [drm:drm_atomic_state_default_clear] Clearing atomic state 000000006fd4f9de
[ 1485.150134] [drm:drm_mode_object_put] OBJ ID : 633 (2)
[ 1485.150149] [drm:drm_mode_object_put] OBJ ID : 642 (2)
[ 1485.150168] [drm:__drm_atomic_state_free] Freeing atomic state 000000006fd4f9de
[ 1485.150333] [drm:drm_mode_obj_get_properties_ioctl] OBJ ID : 423 (2)
[ 1485.150368] [drm:drm_ioctl] comm="drm-event-liste" pid=375, dev=0xe200, auth=1, DRM_IOCTL_MODE_OBJ_GETPROPERTIES
[ 1485.150382] [drm:drm_ioctl] comm="drm-compositor" pid=382, dev=0xe200, auth=1, DRM_IOCTL_MODE_RMFB
[ 1485.150394] [drm:drm_mode_object_put] OBJ ID : 642 (2)
[ 1485.150401] [drm:drm_mode_object_put] OBJ ID : 642 (1)
[ 1485.150408] [drm:drm_mode_obj_get_properties_ioctl] OBJ ID : 423 (2)
[ 1485.150427] [drm:drm_ioctl] comm="drm-event-liste" pid=375, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[ 1485.150693] [drm:drm_ioctl] comm="drm-event-liste" pid=375, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPERTY
[ 1485.150706] [drm:drm_ioctl] comm="drm-event-liste" pid=375, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPBLOB
[ 1485.150716] [drm:drm_mode_object_put] OBJ ID : 646 (2)
[ 1485.150726] [drm:drm_ioctl] comm="drm-event-liste" pid=375, dev=0xe200, auth=1, DRM_IOCTL_MODE_GETPROPBLOB
[ 1485.150736] [drm:drm_mode_object_put] OBJ ID : 646 (2)
[ 1485.152904] [drm:drm_ioctl] comm="drm-event-liste" pid=375, dev=0xe200, auth=1, DRM_IOCTL_MODE_ATOMIC
[ 1485.152928] [drm:drm_atomic_state_init] Allocated atomic state 00000000f10038f4
[ 1485.152956] [drm:drm_atomic_get_plane_state] Added [PLANE:56:Esmart0-win0] 000000005f4a6d8e state to 00000000f10038f4
[ 1485.152970] [drm:drm_atomic_set_property] Set [NOFB] for [PLANE:56:Esmart0-win0] state 000000005f4a6d8e
[ 1485.152985] [drm:drm_atomic_get_plane_state] Added [PLANE:136:Cluster0-win0] 0000000083ddc09c state to 00000000f10038f4
[ 1485.152994] [drm:drm_atomic_set_property] Set [NOFB] for [PLANE:136:Cluster0-win0] state 0000000083ddc09c
[ 1485.153008] [drm:drm_atomic_get_plane_state] Added [PLANE:150:Cluster0-win1] 0000000007efcb0b state to 00000000f10038f4
[ 1485.153030] [drm:drm_atomic_set_property] Set [NOFB] for [PLANE:150:Cluster0-win1] state 0000000007efcb0b
[ 1485.153045] [drm:drm_atomic_get_plane_state] Added [PLANE:248:Esmart0-win1] 000000009dd6e721 state to 00000000f10038f4
[ 1485.153053] [drm:drm_atomic_set_property] Set [NOFB] for [PLANE:248:Esmart0-win1] state 000000009dd6e721
[ 1485.153067] [drm:drm_atomic_get_plane_state] Added [PLANE:262:Esmart0-win2] 000000008e136201 state to 00000000f10038f4
[ 1485.153075] [drm:drm_atomic_set_property] Set [NOFB] for [PLANE:262:Esmart0-win2] state 000000008e136201
[ 1485.153090] [drm:drm_atomic_get_plane_state] Added [PLANE:276:Esmart0-win3] 0000000050459a41 state to 00000000f10038f4
[ 1485.153098] [drm:drm_atomic_set_property] Set [NOFB] for [PLANE:276:Esmart0-win3] state 0000000050459a41
[ 1485.153108] [drm:drm_atomic_check_only] checking 00000000f10038f4
[ 1485.153129] [drm:drm_atomic_commit] committing 00000000f10038f4
[ 1485.153168] [drm:drm_atomic_state_default_clear] Clearing atomic state 00000000f10038f4
[ 1485.153184] [drm:__drm_atomic_state_free] Freeing atomic state 00000000f10038f4
[ 1485.153265] [drm:drm_ioctl] comm="drm-event-liste" pid=375, dev=0xe200, auth=1, DRM_IOCTL_MODE_CREATEPROPBLOB
[ 1485.153321] [drm:drm_ioctl] comm="drm-event-liste" pid=375, dev=0xe200, auth=1, DRM_IOCTL_MODE_ATOMIC
[ 1485.153340] [drm:drm_atomic_state_init] Allocated atomic state 00000000f10038f4
[ 1485.153365] [drm:drm_atomic_get_crtc_state] Added [CRTC:70:video_port0] 0000000026fb6a08 state to 00000000f10038f4
[ 1485.153386] [drm:drm_mode_object_get] OBJ ID : 642 (3)
[ 1485.153406] [drm:drm_atomic_set_mode_prop_for_crtc] Set [MODE:1440x1440] for [CRTC:70:video_port0] state 0000000026fb6a08
[ 1485.153417] [drm:drm_mode_object_put] OBJ ID : 642 (4)
[ 1485.153423] [drm:drm_mode_object_put] OBJ ID : 642 (3)
[ 1485.153439] [drm:drm_mode_object_get] OBJ ID : 423 (2)
[ 1485.153449] [drm:drm_atomic_get_connector_state] Added [CONNECTOR:423:HDMI-A-1] 000000002cdcc342 state to 00000000f10038f4
[ 1485.153456] [drm:drm_mode_object_get] OBJ ID : 423 (3)
[ 1485.153465] [drm:drm_atomic_set_crtc_for_connector] Link [CONNECTOR:423:HDMI-A-1] state 000000002cdcc342 to [CRTC:70:video_port0]
[ 1485.153471] [drm:drm_mode_object_put] OBJ ID : 423 (4)
[ 1485.153479] [drm:drm_atomic_check_only] checking 00000000f10038f4
[ 1485.153490] [drm:drm_atomic_helper_check_modeset] [CRTC:70:video_port0] mode changed
[ 1485.153497] [drm:drm_atomic_helper_check_modeset] [CRTC:70:video_port0] enable changed
[ 1485.153504] [drm:drm_atomic_helper_check_modeset] [CRTC:70:video_port0] active changed
[ 1485.153523] [drm:drm_atomic_helper_check_modeset] Updating routing for [CONNECTOR:423:HDMI-A-1]
[ 1485.153534] [drm:drm_atomic_helper_check_modeset] [CONNECTOR:423:HDMI-A-1] using [ENCODER:422:TMDS-422] on [CRTC:70:video_port0]
[ 1485.153545] [drm:drm_atomic_helper_check_modeset] [CRTC:70:video_port0] needs all connectors, enable : y, active: y
[ 1485.153555] [drm:drm_atomic_add_affected_connectors] Adding all current connectors for [CRTC:70:video_port0] to 00000000f10038f4
[ 1485.153567] [drm:drm_atomic_add_affected_planes] Adding all current planes for [CRTC:70:video_port0] to 00000000f10038f4
[ 1485.153584] [drm:drm_atomic_add_encoder_bridges] Adding all bridges for [encoder:422:TMDS-422] to 00000000f10038f4
[ 1485.153599] [drm:drm_atomic_get_private_obj_state] Added new private object 00000000d5bad693 state 000000000b9d7f14 to 00000000f10038f4
[ 1485.153692] rockchip-vop2 fdd90000.vop : [drm:vop2_crtc_mode_valid] vop2 clock: [198000]
[ 1485.153701] rockchip-vop2 fdd90000.vop : [drm:vop2_crtc_mode_valid] vop2 requested clock [198940]
[ 1485.153745] dwhdmi-rockchip fde80000.hdmi : use tmds mode
[ 1485.153805] [drm:drm_atomic_commit] committing 00000000f10038f4
[ 1485.153836] rockchip-drm display-subsystem : [drm:drm_calc_timestamping_constants] crtc 70: hwmode: htotal 1514, vtotal 1460, vdisplay 1440
[ 1485.153847] rockchip-drm display-subsystem : [drm:drm_calc_timestamping_constants] crtc 70: clock 198940 kHz framedur 11111088 linedur 7610
[ 1485.153855] [drm:drm_atomic_helper_commit_modeset_disables] modeset on [ENCODER:422:TMDS-422]
[ 1485.153867] [drm:drm_atomic_helper_commit_modeset_enables] enabling [CRTC:70:video_port0]
[ 1485.155673] [drm:drm_ioctl] comm="vsync" pid=376, dev=0xe200, auth=1, DRM_IOCTL_WAIT_VBLANK
[ 1485.155691] rockchip-drm display-subsystem : [drm:drm_wait_vblank_ioctl] crtc 0 failed to acquire vblank counter, -22
[ 1485.155698] [drm:drm_ioctl] comm="vsync", pid=376, ret=-22
[ 1485.166783] [drm:drm_ioctl] comm="vsync" pid=376, dev=0xe200, auth=1, DRM_IOCTL_WAIT_VBLANK
[ 1485.166810] rockchip-drm display-subsystem : [drm:drm_wait_vblank_ioctl] crtc 0 failed to acquire vblank counter, -22
[ 1485.166818] [drm:drm_ioctl] comm="vsync", pid=376, ret=-22
[ 1485.177875] [drm:drm_ioctl] comm="vsync" pid=376, dev=0xe200, auth=1, DRM_IOCTL_WAIT_VBLANK
[ 1485.177902] rockchip-drm display-subsystem : [drm:drm_wait_vblank_ioctl] crtc 0 failed to acquire vblank counter, -22
[ 1485.177910] [drm:drm_ioctl] comm="vsync", pid=376, ret=-22
[ 1485.183196] rockchip-vop2 fdd90000.vop : [drm:vop2_crtc_atomic_enable] Update mode to 1440x1440p90, type: 11(if:800) for vp0 dclk: 198940000
[ 1485.183312] rockchip-vop2 fdd90000.vop : [drm:vop2_crtc_atomic_enable] dclk_out0 div: 0 dclk_core0 div: 2
[ 1485.183422] [drm:drm_atomic_helper_commit_modeset_enables] enabling [ENCODER:422:TMDS-422]
[ 1485.183694] rockchip-hdptx-phy-hdmi fed60000.hdmiphy : hdptx_ropll_cmn_config bus_width:1e5b18 rate:1989400
[ 1485.184012] rockchip-hdptx-phy-hdmi fed60000.hdmiphy [31m: hdptx phy pll locked!
[ 1485.184058] dwhdmi-rockchip fde80000.hdmi : final tmdsclk = 198940000
[ 1485.184151] dwhdmi-rockchip fde80000.hdmi : don't use dsc mode
[ 1485.184173] [drm:dw_hdmi_qp_bridge_atomic_enable] No need to set HDR metadata in infoframe
[ 1485.184180] dwhdmi-rockchip fde80000.hdmi : dw hdmi qp use tmds mode
[ 1485.184198] rockchip-hdptx-phy-hdmi fed60000.hdmiphy : bus_width:0x1e5b18,bit_rate:1989400
[ 1485.184429] rockchip-hdptx-phy-hdmi fed60000.hdmiphy [31m: hdptx phy lane locked!
[ 1485.189008] [drm:drm_ioctl] comm="vsync" pid=376, dev=0xe200, auth=1, DRM_IOCTL_WAIT_VBLANK
[ 1485.189033] rockchip-drm display-subsystem : [drm:drm_vblank_enable] enabling vblank on crtc 0, ret: 0
[ 1485.189047] rockchip-drm display-subsystem : [drm:drm_wait_vblank_ioctl] waiting on vblank count 13049, crtc 0
[ 1485.194660] rockchip-drm display-subsystem : [drm:drm_wait_vblank_ioctl] crtc 0 returning 13049 to client
[ 1485.194759] [drm:drm_ioctl] comm="vsync" pid=376, dev=0xe200, auth=1, DRM_IOCTL_WAIT_VBLANK
[ 1485.194776] rockchip-drm display-subsystem : [drm:drm_wait_vblank_ioctl] waiting on vblank count 13050, crtc 0
[ 1485.205798] rockchip-drm display-subsystem : [drm:drm_wait_vblank_ioctl] crtc 0 returning 13050 to client
[ 1485.205881] [drm:drm_ioctl] comm="vsync" pid=376, dev=0xe200, auth=1, DRM_IOCTL_WAIT_VBLANK
