This is a question about changing the HDMI settings for ROCK3c.
nice to meet you. thank you
This is my first time using ROCK3c and I would like some advice.
I wrote “rock-3c_debian_bullseye_xfce_b36.img” to the SD card on Rock3C, and Debian started and worked.
However, it seems that it can only be displayed correctly on an HDMI display that supports 1080p HDMI resolution. (1920x1080)
Previously, with raspberry-pi, I was able to change the HDMI resolution by editing CONFIG.txt, but what should I do with ROCK3C?
Ultimately, I would like to display it at 1024x600 on a 7-inch LCD.
I don’t know how to change it.
I think there’s probably documentation somewhere, but I don’t know.
I would appreciate it if you could tell me how to change it.
thank you.
What interface is the 7-inch display you are planning to use ? (HDMI or MIPI-DSI)
Or, could you please provide us with the specific product name of the monitor ?
Thank you for your reply.
The 7-inch display I plan to use is a 1024x600 TFT display called WF70BTIFHLHTX# with HDMI input.
However, as a result of a connection test, when I connected the ROCK3C directly to a 7-inch display using an HDMI cable, it displayed correctly.
It turns out that the combinations that could not be displayed can only be displayed when an old VGA display is connected with an HDMI/VGA converter.
(There will be no signal.)
The ROCK3C’s screen displayed correctly on a 7-inch HDMI display and a regular desktop HDMI display.
VGA/HDMI converter is ELECOM (AD-HDMIVGABK), maximum frequency is 60HZ
Is this a problem with the refresh rate of AD-HDMIVGABK? That’s what I think.
I think it’s good because I was able to display it directly on the 7-inch display.
When checking the operation, I can only connect a VGA display, so I will think about it for a while.
thank you
This is a correction.
—start -----------------
It turns out that the combinations that could not be displayed cannot be displayed when an old VGA display is connected with an HDMI/VGA converter. (There will be no output signal.)
— end --------------
Google Translation ↓
> 7インチディスプレイに直接表示できたので良かったと思います。
解決済みという事ですか ?
> 古いVGAディスプレイをHDMI/VGAコンバータで接続すると、表示できなかった組み合わせが表示できないことが判明しました。(出力信号はありません。)
意味が判りません。
エレコムの “HDMI-VGA変換アダプタ - AD-HDMIVGABK” に関しては、正しく機能できるかどうか怪しいです。
*)所謂 “VGA” が隆盛の頃は “EDID” 機能が必須という事でもなく、結果 その実装もいい加減だった。そういった時代的な背景が理由として挙げられます。
他方 “WF70BTIFHLHTX” ですが、“EDID” 情報が正しく取得出来ていれば、貴方が期待する解像度(1024x600@60) で機能する可能性が有ると思われます。
*)但し、“WF70BTIFHLHTX” 紹介のページには、“HDMIコネクタ: (Only DVI Signal)” と記載されてますので、どれ程頑張っても音声は出力できないハズです。
/var/log/Xorg.0.log を見て、“EDID” 情報が正しく取得できているか確認してみてください。
私が確認したのは、“rock-3c_debian_bullseye_xfce_b39.img” ですが、このイメージでは “EDID” 情報が取得されていませんでした。
*)私が使用しているモニターは標準的な “1920x1080@60” で、この場合は特に不都合も無く、結果 私自身も問題に気付いてなかっただけ と言う事ですね。
あなたが試用したイメージ: “b36” でも、おそらく同じだと思います。
“rock-3c” ボード自体は、HDMI@解像度(1024x600@60) の信号を出力できる事を確認していますので、
貴方の期待通りの解像度で機能するかどうかは、“EDID” 次第だと考えられます。
日本語で詳細な内容をありがとうございます。
debian bullseye b39でも動作させました。
7インチディスプレイには、表示できたので、ひとまずは、OKとなります。
VGA/HDMIコンバーターの問題ですが、最大周波数が60Hzまでなので、その影響かと考えていましたが、
別のそれまで使用していたWindows10のPCでも表示されないので、どうやら壊れてしまった様子です。
しかしEDIDは取得できているようです。
以下は、「/var/log/Xorg.0.log」の一部です。
— I-O DATA DEVICE,INC. LCD-A173V - Start --------------------------------------------------------------------------
[ 12.881] (II) modeset(0): glamor X acceleration enabled on Mali-G52
[ 12.882] (II) modeset(0): glamor initialized
[ 12.882] (II) modeset(0): FlipFB: Always, limited to: -1 fps
[ 13.054] (II) modeset(0): Output HDMI-1 using monitor section Default Monitor
[ 13.055] (**) modeset(0): Option “Rotate” “normal”
[ 13.055] (II) modeset(0): Bind output 111 to current crtc 68.
[ 13.104] (II) modeset(0): EDID for output HDMI-1
[ 13.104] (II) modeset(0): Printing probed modes for output HDMI-1
[ 13.105] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 13.105] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 13.105] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 13.105] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 13.105] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 13.105] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 13.105] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 13.105] (II) modeset(0): Modeline "1440x900"x75.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 13.105] (II) modeset(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 13.105] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 13.105] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 13.105] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 13.105] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 13.105] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 13.106] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 13.106] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 +hsync +vsync (48.4 kHz e)
[ 13.106] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 13.106] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 13.106] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 13.106] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 13.106] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 13.106] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 13.106] (II) modeset(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 13.107] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 13.107] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 13.107] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 13.107] (II) modeset(0): Output HDMI-1 connected
[ 13.107] (II) modeset(0): Using exact sizes for initial modes
[ 13.107] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0
[ 13.107] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 13.107] (==) modeset(0): DPI set to (96, 96)
— I-O DATA DEVICE,INC. LCD-A173V - End --------------------------------------------------------------------------
— 7’inch LCD display Start ------------------------------------------------------------------------------------------
[ 10.515] (II) modeset(0): glamor X acceleration enabled on Mali-G52
[ 10.515] (II) modeset(0): glamor initialized
[ 10.515] (II) modeset(0): FlipFB: Always, limited to: -1 fps
[ 10.667] (II) modeset(0): Output HDMI-1 using monitor section Default Monitor
[ 10.667] (**) modeset(0): Option “Rotate” “normal”
[ 10.667] (II) modeset(0): Bind output 111 to current crtc 68.
[ 10.687] (II) modeset(0): EDID for output HDMI-1
[ 10.688] (II) modeset(0): Printing probed modes for output HDMI-1
[ 10.688] (II) modeset(0): Modeline "1024x600"x59.8 50.25 1024 1068 1156 1344 600 603 609 625 -hsync -vsync (37.4 kHz e)
[ 10.688] (II) modeset(0): Output HDMI-1 connected
[ 10.688] (II) modeset(0): Using sloppy heuristic for initial modes
[ 10.688] (II) modeset(0): Output HDMI-1 using initial mode 1024x600 +0+0
[ 10.688] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 10.688] (==) modeset(0): DPI set to (96, 96)
— 7’inch LCD display End ------------------------------------------------------------------------------------------
以上です。
当面は、7inch LCD Displayを使用します。
ありがとうございます。
LCD-A173V 調べてみると、その解像度は 1280×1024 のようです
しかし、提示されたログをみると
とあり、モニターの仕様と合致しません。ようするに"EDID"が取得できていないという事です。
貴方が設定を変えていないかぎり、少なくとも"b39"の元の設定では"EDID"の取得が禁止されています。
不要なトラブルを避ける為でしょうが、標準的な "1920x1080"x60.0 を含む設定を強制しておけば問題は少ないだろう との判断でしょう。
“EDID” が正しく取得されている場合、下のような出力が得られます。
IO-DATA:EX-LDH241D の例
[ 26628.754] (II) modeset(0): Serial No: 128U135xxxx
[ 26628.755] (II) modeset(0): Monitor name: EX-LDH241D
[ 26628.755] (II) modeset(0): Supported detailed timing:
[ 26628.755] (II) modeset(0): clock: 138.5 MHz   Image Size:  527 x 296 mm
[ 26628.755] (II) modeset(0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 26628.755] (II) modeset(0): v_active: 1080  v_sync: 1083  v_sync_end 1088 v_blanking: 1111 v_border: 0
[ 26628.755] (II) modeset(0): Number of EDID sections to follow: 1
[ 26628.755] (II) modeset(0): EDID (in hex):
[ 26628.755] (II) modeset(0):   00ffffffffffff0025e43e18d6880000
[ 26628.755] (II) modeset(0):   1c1e010380351e782a8e61a657519f27
[ 26628.755] (II) modeset(0):   0f5054210800818081c0a9c001010101
[ 26628.757] (II) modeset(0):   00000000000000000000000000000000
[ 26628.757] (II) modeset(0):   0000000000000000000000000000002d
[ 26628.757] (II) modeset(0): Printing probed modes for output HDMI-1
[ 26628.757] (II) modeset(0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz eP)
[ 26628.757] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 26628.759] (II) modeset(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 26628.759] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 26628.759] (II) modeset(0): Output HDMI-1 connected
ファイル “/etc/X11/xorg.conf.d/20-modesetting.conf” 内のオプションをコメントアウト変更して試してみてください
【変更前】 Option “NoEDID” “true”
【変更後】# Option “NoEDID” “true”
20-modesetting.confを修正しましたが、表示されません。
VGA/HDMI変換器を、それまで使用していた、Windows10のPCに接続しても、表示されないので、おそらく、ELECOM AD-HDMIVGABK(VGA/HDMI変換器)もしくは、I-O DATA DEVICE,INC. LCD-A173V側がおかしいと考えます。
EDIDに関しては、以下の通りになりました。
[ 10.609] (II) modeset(0): Monitor name: VGA DISPLAY
[ 10.609] (II) modeset(0): Unknown vendor-specific block 0
[ 10.609] (II) modeset(0): Supported detailed timing:
[ 10.609] (II) modeset(0): clock: 328.3 MHz Image Size: 0 x 0 mm
[ 10.609] (II) modeset(0): h_active: 1077 h_sync: 1077 h_sync_end 1105 h_blank_end 1077 h_border: 0
[ 10.609] (II) modeset(0): v_active: 132 v_sync: 132 v_sync_end 132 v_blanking: 231 v_border: 0
[ 10.609] (II) modeset(0): Number of EDID sections to follow: 1
[ 10.609] (II) modeset(0): EDID (in hex):
[ 10.609] (II) modeset(0): 00ffffffffffff000d1278c30a000000
[ 10.609] (II) modeset(0): 15160103a2583278229d81a3544c9926
[ 10.609] (II) modeset(0): 0f5054bdcf0071408100814081809500
[ 10.609] (II) modeset(0): 950fb300a94064190040410026301888
[ 10.610] (II) modeset(0): 3600a05a0000001e023a801871382d40
[ 10.610] (II) modeset(0): 582c4500a05a0000001e000000fd0032
[ 10.610] (II) modeset(0): 3c1e440f010a202020202020000000fc
[ 10.610] (II) modeset(0): 0056474120444953504c41590a200196
[ 10.610] (II) modeset(0): 02031b6123097f078301000067030c00
[ 10.610] (II) modeset(0): 1000802d43011004e2000f0000360040
[ 10.610] (II) modeset(0): e86300001a1a1d008051d01c20408035
[ 10.610] (II) modeset(0): 0040846300001c000000000000000000
[ 10.610] (II) modeset(0): 00000000000000000000000000000000
[ 10.610] (II) modeset(0): 000000000000000000000000000000a6
[ 10.611] (–) modeset(0): HDMI max TMDS frequency 225000KHz
[ 10.611] (II) modeset(0): Printing probed modes for output HDMI-1
[ 10.611] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 10.611] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 10.611] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 10.612] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 10.612] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 10.612] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 10.612] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 10.612] (II) modeset(0): Modeline "1440x900"x75.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 10.612] (II) modeset(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 10.612] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 10.612] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 10.612] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 10.612] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 10.612] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 10.612] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 10.613] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 +hsync +vsync (48.4 kHz e)
[ 10.613] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 10.613] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 10.613] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 10.613] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 10.613] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 10.614] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 10.614] (II) modeset(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 10.614] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 10.614] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 10.614] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 10.614] (II) modeset(0): Output HDMI-1 connected
[ 10.614] (II) modeset(0): Using exact sizes for initial modes
[ 10.614] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0
[ 10.615] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 10.615] (==) modeset(0): DPI set to (96, 96)
別のVGAディスプレイでも確認しました。
結果は同じく、何も表示されません。(無信号状態)
先ほどの「I-O DATA DEVICE,INC. LCD-A173V」ディスプレイは、
別のWindows PCに直接VGAコネクタに差し込んだら、表示されました。
やはり、HDMI/VGA変換器が怪しいと思われます。
— NEC LCD172V - Start --------------------------------------------------------------------------
[ 10.865] (II) modeset(0): glamor X acceleration enabled on Mali-G52
[ 10.865] (II) modeset(0): glamor initialized
[ 10.865] (II) modeset(0): FlipFB: Always, limited to: -1 fps
[ 11.045] (II) modeset(0): Output HDMI-1 using monitor section Default Monitor
[ 11.045] (**) modeset(0): Option “Rotate” “normal”
[ 11.045] (II) modeset(0): Bind output 111 to current crtc 68.
[ 11.102] (WW) EDID timing clock 328.32 exceeds claimed max 145MHz, fixing
[ 11.102] (II) modeset(0): EDID for output HDMI-1
[ 11.103] (II) modeset(0): Manufacturer: NEC Model: 67c4 Serial#: 16843009
[ 11.103] (II) modeset(0): Year: 2012 Week: 21
[ 11.105] (II) modeset(0): EDID Version: 1.3
[ 11.105] (II) modeset(0): Digital Display Input
[ 11.105] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 27
[ 11.105] (II) modeset(0): Gamma: 2.20
[ 11.105] (II) modeset(0): DPMS capabilities: Off
[ 11.106] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 11.106] (II) modeset(0): First detailed timing is preferred mode
[ 11.123] (II) modeset(0): redX: 0.648 redY: 0.335 greenX: 0.293 greenY: 0.602
[ 11.123] (II) modeset(0): blueX: 0.146 blueY: 0.071 whiteX: 0.313 whiteY: 0.329
[ 11.123] (II) modeset(0): Supported established timings:
[ 11.123] (II) modeset(0): 720x400@70Hz
[ 11.123] (II) modeset(0): 640x480@60Hz
[ 11.123] (II) modeset(0): 640x480@67Hz
[ 11.123] (II) modeset(0): 640x480@72Hz
[ 11.123] (II) modeset(0): 640x480@75Hz
[ 11.123] (II) modeset(0): 800x600@56Hz
[ 11.123] (II) modeset(0): 800x600@60Hz
[ 11.123] (II) modeset(0): 800x600@72Hz
[ 11.123] (II) modeset(0): 800x600@75Hz
[ 11.124] (II) modeset(0): 832x624@75Hz
[ 11.124] (II) modeset(0): 1024x768@60Hz
[ 11.124] (II) modeset(0): 1024x768@70Hz
[ 11.124] (II) modeset(0): 1024x768@75Hz
[ 11.124] (II) modeset(0): 1280x1024@75Hz
[ 11.124] (II) modeset(0): 1152x864@75Hz
[ 11.124] (II) modeset(0): Manufacturer’s mask: 0
[ 11.124] (II) modeset(0): Supported standard timings:
[ 11.124] (II) modeset(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 11.124] (II) modeset(0): #1: hsize: 1280 vsize 960 refresh: 75 vid: 20353
[ 11.124] (II) modeset(0): Supported detailed timing:
[ 11.124] (II) modeset(0): clock: 108.0 MHz Image Size: 338 x 270 mm
[ 11.124] (II) modeset(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
[ 11.124] (II) modeset(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
[ 11.124] (II) modeset(0): Ranges: V min: 56 V max: 75 Hz, H min: 31 H max: 81 kHz, PixClock max 329 MHz
[ 11.125] (II) modeset(0): Monitor name: LCD172V
[ 11.125] (II) modeset(0): Serial No: 25310649NJ
[ 11.125] (II) modeset(0): Unknown vendor-specific block 0
[ 11.125] (II) modeset(0): Supported detailed timing:
[ 11.125] (II) modeset(0): clock: 328.3 MHz Image Size: 0 x 0 mm
[ 11.125] (II) modeset(0): h_active: 1077 h_sync: 1077 h_sync_end 1105 h_blank_end 1077 h_border: 0
[ 11.125] (II) modeset(0): v_active: 132 v_sync: 132 v_sync_end 132 v_blanking: 231 v_border: 0
[ 11.125] (II) modeset(0): Number of EDID sections to follow: 1
[ 11.125] (II) modeset(0): EDID (in hex):
[ 11.125] (II) modeset(0): 00ffffffffffff0038a3c46701010101
[ 11.125] (II) modeset(0): 15160103a0221b782a3095a6554b9a25
[ 11.125] (II) modeset(0): 125054bfef80714f814f010101010101
[ 11.125] (II) modeset(0): 010101010101302a009851002a403070
[ 11.125] (II) modeset(0): 1300520e1100001e000000fd00384b1f
[ 11.126] (II) modeset(0): 510e000a202020202020000000fc004c
[ 11.126] (II) modeset(0): 4344313732560a2020202020000000ff
[ 11.126] (II) modeset(0): 0032353331303634394e4a0a20200164
[ 11.126] (II) modeset(0): 02031b6123097f078301000067030c00
[ 11.126] (II) modeset(0): 1000802d43011004e2000f0000360040
[ 11.126] (II) modeset(0): e86300001a1a1d008051d01c20408035
[ 11.126] (II) modeset(0): 0040846300001c000000000000000000
[ 11.126] (II) modeset(0): 00000000000000000000000000000000
[ 11.127] (II) modeset(0): 00000000000000000000000000000000
[ 11.127] (II) modeset(0): 000000000000000000000000000000a6
[ 11.128] (–) modeset(0): HDMI max TMDS frequency 225000KHz
[ 11.128] (II) modeset(0): Printing probed modes for output HDMI-1
[ 11.128] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 11.128] (II) modeset(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 11.128] (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 11.128] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 11.128] (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 11.128] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 11.128] (II) modeset(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 11.128] (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 11.129] (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 11.129] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 11.129] (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 11.129] (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 11.129] (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 11.129] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 11.129] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 11.129] (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 11.129] (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 11.129] (II) modeset(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 11.129] (II) modeset(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 11.129] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 11.129] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 11.131] (II) modeset(0): Output HDMI-1 connected
[ 11.131] (II) modeset(0): Using exact sizes for initial modes
[ 11.131] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +0+0
[ 11.131] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 11.132] (==) modeset(0): DPI set to (96, 96)
— NEC LCD172V - End --------------------------------------------------------------------------
それは、おそらく “ELECOM AD-HDMIVGABK(VGA/HDMI変換器)” が作り出した情報ですね。
"EDID"データ自体は、正しく取得出来ているようですが、
本来、モニターが対応できない値("1920x1080"x60.0 148.50MHz)が報告されいて、
"rock-3c"ボード側は それに対応した解像度で出力 => 結果 何も表示されない。 というオチだと思います。
可能なら、その状態(今の状態)で “WF70BTIFHLHTX” 直接に接続してみてください。
EDID (in hex):
が取得され、
そのデコード結果に
Modeline "1280x600"x60.0
が含まれるているようであれば、そのまま映る可能性があります。
“WF70BTIFHLHTX” ですが、台湾の製品のようですね。
日本では、あまり見かけない製品ですが、もしかして台湾の方ですか ?
因みに、私は母国語以外は全く駄目です。
代理店から台湾経由で以前購入したものです。
7inch LCD表示自体は、正常に表示しています。
表示成功:
7inch LCD…HDMIで直接接続
表示失敗(信号なし):
I-O DATA DEVICE,INC. LCD-A173V…HDMI/VGA変換器経由で接続
NEC LCD172V…HDMI/VGA変換器経由で接続
上記液晶は、VGA接続にすると正常に表示され、
別のWindows10のPCに同じ状態で接続しても表示されず、
VGA出力のあるPCでは、2つとも正常表示されることから、
HDMI/VGA変換器が故障したものと考えています。
表示成功:
7inch LCD…HDMIで直接接続
本命の目的は、既に達成済みと言う事ですね、それは良かった。
VGA変換器ですが、私も使った経験があります …が、やはり1年程度で壊れてしまいました。
確かに、貴方が言うように故障した可能性は十分にあります。
試しに、“kernel parameter” に “drm.edid_firmware=HDMI-A-1:edid/1280x1024.bin” を追加して試してみてください
パラメータの追加場所は、ファイル “/boot/extlinux/extlinux.conf” 内の、“append” で始まる行です。
例)
    append root=UUID=xxxxx … drm.edid_firmware=HDMI-A-1:edid/1280x1024.bin
これで "EDID"の情報が、“1280x1024@60” のみに強制されます。(LCD-A173Vの対応最高解像度)
これでも映らないなら、残念ながら壊れてしまった可能性が高いいでしょう。
1280x1024にはなったようですが、液晶画面には何も表示されません。
HDMI/VGA変換器の故障と考えられます。
7inch 液晶で使用します。
ありがとうございます。
[ 10.501] (II) modeset(0): glamor X acceleration enabled on Mali-G52
[ 10.501] (II) modeset(0): glamor initialized
[ 10.501] (II) modeset(0): FlipFB: Always, limited to: -1 fps
[ 10.514] (II) modeset(0): Output HDMI-1 using monitor section Default Monitor
[ 10.514] (**) modeset(0): Option “Rotate” “normal”
[ 10.514] (II) modeset(0): Bind output 111 to current crtc 68.
[ 10.515] (II) modeset(0): EDID for output HDMI-1
[ 10.515] (II) modeset(0): Manufacturer: LNX Model: 0 Serial#: 0
[ 10.515] (II) modeset(0): Year: 2012 Week: 5
[ 10.515] (II) modeset(0): EDID Version: 1.3
[ 10.516] (II) modeset(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 10.516] (II) modeset(0): Sync: Separate CompositeSerration on. V.Sync Pulse req. if CompSync or SyncOnGreen
[ 10.516] (II) modeset(0): Max Image Size [cm]: horiz.: 44 vert.: 35
[ 10.516] (II) modeset(0): Gamma: 2.20
[ 10.516] (II) modeset(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
[ 10.516] (II) modeset(0): First detailed timing is preferred mode
[ 10.516] (II) modeset(0): redX: 0.642 redY: 0.349 greenX: 0.292 greenY: 0.596
[ 10.516] (II) modeset(0): blueX: 0.147 blueY: 0.125 whiteX: 0.312 whiteY: 0.328
[ 10.516] (II) modeset(0): Manufacturer’s mask: 0
[ 10.517] (II) modeset(0): Supported standard timings:
[ 10.517] (II) modeset(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 10.517] (II) modeset(0): Supported detailed timing:
[ 10.517] (II) modeset(0): clock: 108.0 MHz Image Size: 444 x 355 mm
[ 10.517] (II) modeset(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
[ 10.517] (II) modeset(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
[ 10.517] (II) modeset(0): Serial No: Linux #0
[ 10.517] (II) modeset(0): Ranges: V min: 59 V max: 61 Hz, H min: 62 H max: 64 kHz, PixClock max 115 MHz
[ 10.517] (II) modeset(0): Monitor name: Linux SXGA
[ 10.517] (II) modeset(0): EDID (in hex):
[ 10.517] (II) modeset(0): 00ffffffffffff0031d8000000000000
[ 10.517] (II) modeset(0): 051601036d2c2378ea5ec0a4594a9825
[ 10.517] (II) modeset(0): 20505400000081800101010101010101
[ 10.518] (II) modeset(0): 010101010101302a009851002a403070
[ 10.518] (II) modeset(0): 1300bc631100001e000000ff004c696e
[ 10.518] (II) modeset(0): 75782023300a20202020000000fd003b
[ 10.518] (II) modeset(0): 3d3e400b000a202020202020000000fc
[ 10.518] (II) modeset(0): 004c696e757820535847410a202000a0
[ 10.518] (II) modeset(0): Printing probed modes for output HDMI-1
[ 10.518] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 10.518] (II) modeset(0): Output HDMI-1 connected
[ 10.518] (II) modeset(0): Using exact sizes for initial modes
[ 10.518] (II) modeset(0): Output HDMI-1 using initial mode 1280x1024 +0+0
[ 10.519] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 10.519] (==) modeset(0): DPI set to (96, 96)
