There is no wifi interface in openwrt
Good day. I got Pi E today, installed Openwrt, but there is no wifi interface .. What should I do?
openwrt-rockchip-armv8-radxa_rock-pi-e-ext4-sysupgrade.img
in the web interface is also missing wireless…
the module is not working properly? return?
Thnx
I am running the same problem :frowning:
Rock Pi E that I bought has 512MB. So I believe it has RTL8723DU (Wlan 2.4GHz 802.11b/g/n and Bluetooth 4.2).
When I booted the board, though I see the blue LED light blinking, I don’t see “Wireless” listed under “Network” when I log into LuCI admin portal from the browser. And I am not sure what I should look for from “dmesg” output.
When I installed Armbian, the same board boots up fine and WiFi is also working fine ! I was able to connect it to my home network and I could also have it as an Access Point as well.
I would like to use OpenWRT as it has everything else out of the box for our needs.
I am not a driver developer or any expert.
Being naive here : Wondering if anyone will take the code from Armbian codebase and port it to OpenWRT (assuming it’s all possible techincally and legally) ?
I followed this thread and at the end of it, Stephen from Radxa team has posted the link for the driver code (Index of /rockpie/source/wifi) for RTL8723DU.
Can anyone share the knowledge in how to integrate the above code into OpenWRT so that it can work with the 512 MB version of Rock Pi E ?
Apprecaite any thoughts, advice.
I am waiting for the solution.
