I had no screen and use cli on ROCK 5C Lite. i use the nmcli to connect wifi.
However , i was not able to re-conn the wifi when i reboot the board.
i found that the interface name of wifi will change after reboot.
As can be seen in the picture, this cause networkmanger cant found the interface in saved conf file.
i use the following command
ln -s /dev/null /etc/udev/rules.d/80-net-setup-link.rules
and the wifi name is stable as wlan0
and it can re-conn the wifi after reboot.
It’s a feature or bug ? Need fix.
Please install this udev deb.
radxa-udev_0.1.1_all.zip (2.9 KB)
ok, i will try it later
