I have been talking to Ahmad Byagowi from Meta, he helms the OCP-TAP project which has done a lot of great work getting various small computers working with PTP time sync.
The i226-V NIC on the X4 can support PTP hardware timestamps if, I believe, TGPIO support is enabled in the AMI BIOS, and Ahmad also worked with the LattePanda team to get it enabled on the Mu: https://github.com/LattePandaTeam/LattePanda-Mu/issues/4
If enabled, and T_Sync 0 and T_Sync 1 are exposed somewhere on the board, this could be used for cheap but highly accurate time services.
@ryann, please let me know if you need any help from AMI on the BIOS changes necessary to enable TGPIO.
Also, would you please look into your schematic to see if T_Sync 0 and T_Sync 1 are somehow accessible, at least brought out from under your chipset.
Looking forward to your response.
Okay thank you! At a minimum, PTP support is useful already. If there is any opportunity for the TGPIO to be exposed in a future revision, that would be a huge assistance for using the X4 in time-critical situations.
Ryann,
Thx for this, assume PTP is enabled by default ? No need to change BIOS settings?
Also re geerlingguy's question, assume given the RP2040 RPI chip is the one controlling the 40pin GPIO, there is now way to pass TGPIO via the RPI2040......
Thanks
Ryann,
Just wanting to see if there is an ETA for next release of Radxa X4 Hardware with TGPIO Sync Signals routed out from PCB ?
Thanks in advance.
Chris
Hi Ryann,
Just checking up to see if the next next version was produced last month, i.e. support for TGPIO Sync ?
If so how do specifically order that variant.
Due to the shortage of Intel N100/N150 chips, we have to stopped production of the X4. We will resume production as soon as the CPU supply issue is resolved, possibly X4 or X5
