Tests and benchmarks
I posted that in telegram group, so photos-proof can be found there. Here is my data:
No load (except armbian monitor).
No fan, Heatsink with glue
Voltage
9.31-9.34V
Ampers
0.24A without anything plugged in
0.30A with Internet plugged in
Temperature
46.2° (it’s winter time and this time RockPi is on floor, so it’s actually have somekind of wind current)
Power Consumption
5.2-5.3W without anything plugged.
6.1-6.2W with internet plugged in
100% load
With AOM building with all 6 cores in.
Voltage
9.34V
Ampers
0.84A
Temperature
Got to 80° on 44%
On 60% it was 85 so i stopped
Power Consumption
16-17W
No load
With fan and heatsink with glue
Temperature
30°
All others parameters are same
100% load
With FFmpeg building.
With fan, heatsink with glue.
CPU: 99% (BIG-1800, little-1416)
Voltage
9.35
Ampers:
0.80-0.83A
Power Consumption
16.4W-16.6W with spikes up to 17W
Temperature
56.1-58.3°
No load
With fan and heatsink with thermal compound.
Temperature
27.5°-28.1°
All others parameters the same
100% load
With FFmpeg building with all cores on
With fan, heatsink with thermal compound.
Temperature
46.2°-47.5°
P.S. Additional info.
Noise from fan
1cm - 68 dB, 30cm - 37 dB, noise around 30db (can be reduced by making more accurate holes for air)
