pbies
January 23, 2020, 10:30pm
1
What I am trying to do is make Rock say the current hour each exact hour. I know how to do that in cron, but there are problems earlier.
I’ve installed alsa-utils and espeak. I make alsa play some sounds:
aplay /usr/share/sounds/alsa/*
However espeak does not work:
espeak "Text you wish to hear back"
The are many errors:
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
Expression 'PaAlsaStreamComponent_FinishConfigure( &self->playback, hwParamsPlayback, outParams, self->primeBuffers, realSr, outputLatency )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2738
Expression 'PaAlsaStream_Configure( stream, inputParameters, outputParameters, sampleRate, framesPerBuffer, &inputLatency, &outputLatency, &hostBufferSizeMode )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2843
snd-bcm2835 is not available in modules…
How can I make Rock talk to me?
igorp
January 23, 2020, 11:09pm
2
This is not Raspberry Pi:
pbies
January 23, 2020, 11:26pm
3
As always your comments are very useful…
aplay does play sound but not from espeak, mplayer gives silence even when playing sound and espeak gives error.
pbies
January 24, 2020, 3:14am
4
@Stephen can you help with that?
pbies
January 25, 2020, 12:14am
5
Got it!
Use these commands:
> /etc/asound.conf
> ~/.asoundrc
alsamixer
aplay -l
apt install alsa-utils
apt install espeak
apt install mplayer
apt install pulseaudio
apt install pulseaudio-module-jack
espeak "Hello World!"
espeak "Hello World!" --stdout > /test.wav
espeak "Hello World!" --stdout | aplay
pactl set-default-sink alsa_output.platform-es8316-sound.analog-stereo
pulseaudio --start
adduser root audio
First two files need some special content.
Now espeak works!
For the problem I have found the solution to add line in /etc/crontab:
0 * * * * root /root/hour
and put in /root/hour file following script:
#!/usr/bin/env bash
h=$(date +"%H")
pulseaudio --start
case "$h" in
"10") espeak -v pl "godzina dziesiąta" --stdout | paplay ;;
"11") espeak -v pl "godzina jedenasta" --stdout | paplay ;;
"12") espeak -v pl "godzina dwunasta" --stdout | paplay ;;
"13") espeak -v pl "godzina trzynasta" --stdout | paplay ;;
"14") espeak -v pl "godzina czternasta" --stdout | paplay ;;
"15") espeak -v pl "godzina piętnasta" --stdout | paplay ;;
"16") espeak -v pl "godzina szesnasta" --stdout | paplay ;;
"17") espeak -v pl "godzina siedemnasta" --stdout | paplay ;;
"18") espeak -v pl "godzina osiemnasta" --stdout | paplay ;;
"19") espeak -v pl "godzina dziewiętnasta" --stdout | paplay ;;
"20") espeak -v pl "godzina dwudziesta" --stdout | paplay ;;
"21") espeak -v pl "godzina dwudziesta pierwsza" --stdout | paplay ;;
"22") espeak -v pl "godzina dwudziesta druga" --stdout | paplay ;;
"23") espeak -v pl "godzina dwudziesta trzecia" --stdout | paplay ;;
"00") espeak -v pl "północ" --stdout | paplay ;;
"01") espeak -v pl "godzina pierwsza" --stdout | paplay ;;
esac
Which tells me each full hour which hour is it.
