Support disablement of little cores in the mainstream firmware?
Hi Radxa team, I’m using an OS that needs to disable the little cores (4xA520) for compatibility, the current 9.0.0 SystemReady firmware works ok for now but I’m wondering if the mainstream firmware could also provide an option to disable the little cores? I’m trying to use https://github.com/andreiw/MultiArchUefiPkg with the firmware but the SystemReady version doesn’t seem to provide the souce code for build.
Thanks!
@RadxaYuntian can you give us more info about a new firmware update?
Not much other than we are working on it. You can check the GitHub repo to see what we are working on,
