I’d like to suggest a few changes to the X2L board to make it easier to use in IoT settings and for single-board-computer clusters.
Add header pins to power and reset push-button swithces and LEDs for use in wiring up for use with external buttons and LEDs for use in cases and for remote interfaces. (Ideally, design and sell a kit for use in such settings.)
Add pins for external fan for use in enclosures.
Add a barrel-style 12V connector, useful as a supplement or alternative option in place of the USB-C one. This is especially useful when using with PoE using 48V --> 12V adapters as it’s hard to find any PoE adapters that terminate in USB-C.
Beyond this I’d like to encourage suggestions in this forum, inside or outside of this thread.
Replacing USB-C with a barrel jack would break convenience for normal users. I’m not sure if the board can accept 12V through USB-C but if it does, then there are simple electrical adapters. I, for example, straight up refuse to buy SBCs not powered with USB-C.
I didn’t say “replace”, but “add.” The problem with USB-C-only is that multiple USB-C chargers, especially ones with any sort of switchable control over the power, are almost impossible to find for any large number of connectors, and PoE-to-12V adapters always come with barrel connectors, not USB-C ones. The convenience of USB-C vanishes when you are dealing with multiple boards for this reason.
Thanks! Yes, I went down that rabbit hole and found a wealth of sizes and options, but so far have not yet found something that will carry 12V from a barrel plug to a USB-C one. For example, for that particular part, here is the notation: " * (Note: It can work normally only when the output voltage is 5V, and the maximum current is 3A. The maximum power is 15W. The output voltage cannot be 9V-12V.)Use a 5V power adapter with a barrel connector to power and charge SB Type C 2.0 devices.And the Type C 2.0 port can also charge DC devices." But perhaps supplying an adapter taht works could be an option for Radxa, or finding a part to suggest that works with 12V.
Header pins or a connector for power button and led would be good, also the usb 2.0 and audio jack could be changed to a connector like the fan connector, this would keep functionality and add versatility, also radxa could make the add on kits to sell with various wire lengths,
a 2nd m-key m.2 underneath would be great
1 sata and sata power port would be a nice to have too
removable emmc
micro sd reader
upgradeable and removable ram modules
i just finished setting my radxa x2L,it works great, its set up as a mini desktop pc with a raspberry pi 7" screen its a nice fit, Bluetooth sound is great on it and video playback is smooth, I haven’t tested any games yet but plan to
i had it mining crypto on unmineable for a few hours to see how its cpu is compared to my laptop, the radxa X2L was boosting up to 2.5ghz, it gets 300h - 400h on the xmrig algorithm, 65 degrees c on all 4 cores, core 0 and 1 at 100% load and core 3 and 4 at 80% load, the 4 core Celeron is great for most tasks but i love to see 1 with a more cores, and because i want to try a gpu on it that gets me thinking about a water cooling block for the x2L or its upcoming replacements
