FleeDK
March 18, 2019, 7:52pm
1
Hey guys,
Very simple questions, from a newbee to RockPi 4 using your image:
rockpi4b-ubuntu-bionic-minimal-20190104_2101-gpt.img
After flashing my MicroSD card using above mentioned image, everything works great !
What is the Rock Pi (Radxa) official-correct way to set a static IP, subnet, Gateway and NS for the wired nic port (eth0) - not wifi ?
And correct way to disable ipv6 on eth0
I’m asking since Netplan is not included, and there is a lot of different answers to be found when crawling the web.
If the answer is as simple as --> sudo netplan generate <-- and then just go the standard way from there, then perfect
Thanx a lot.
/Flemming
FleeDK
March 21, 2019, 8:59am
2
Hey Guys,
Didn’t get any feedback
If others have the same challenges, this is how I managed to solve it - with help from my pal Danial Bahl
Static IPv4
We found the nmtui interface simple and usefull.
Disable IPv6
check your current IPv6 address
ifconfig -a | grep inet6
Add the following to /etc/sysctl.conf - configuration file for setting system variables
net.ipv6.conf.all.disable_ipv6=1
net.ipv6.conf.default.disable_ipv6=1
Then reboot your RockPi.
Best rgz,
/Flemming
jack
March 21, 2019, 9:34am
3
Hi, FleeDK
Thanks for sharing it. We are not network experts and now we leant something new
bdmak
November 4, 2019, 6:10am
4
Thanks for posting this @FleeDK . I couldn’t seem to get static IPs setup using the desktop GUI on the Debian image however using nmtui did the trick!
FYI the setup I got working was using the same static IP for wlan0 and eth0 with eth0 as a priority.
Unfortunately this did not work for me after I changed to the ip. I activated the nic (wired network - eth0) and then rebooted and it was blank yet again.
However it did give me 3 ip addresses on my wifi adapter.
