Setup Info
Board - Rockpi S
SD Card - Sandisk class 10 16Gb
OS - rockpis_debian_stretch_minimal_arm64_190806_0234-gpt.img
Did anyone notice a similar problem?
Please guide
Thank you
Setup Info
Board - Rockpi S
Please guide
Thank you
sudo iwconfig wlan0 power off
that will shut off wireless, right? What if I wish to use WiFi & BLE along with ethernet?
anyway, I checked the same & no luck!
[sudo] password for rock:
Error for wireless request “Set Power Management” (8B2C) :
SET failed on device wlan0 ; Operation not permitted.
it throws an error, but the radio is turned off. I even checked it with nmcli, but no luck either
sudo nmcli radio wifi off
the delay still prevails
Just turn off the power-saving mode.
We’ll have a look tomorrow.
Hi nccchirag, try
sudo iwconfig p2p0 power off
or
Sorry no luck for either! it takes around 7sec for command prompt to be active on Putty via SSH
rock@rockpis:~$ sudo iwconfig p2p0 power off
SET failed on device p2p0 ; Operation not permitted.
I also tried instructions mentioned here, but no luck
thank you
