I’ve downloaded the (~20GB once unpacked!) usb-install image from https://docs.radxa.com/en/orion/o6/download -> https://dl.radxa.com/orion/o6/images/debian/orion-o6-usb-install-debian12-preinstalled-desktop-b3.img.gz and have written it to a USB drive.
Plugging this in and powering on gets me to a grub prompt.
From here, I can configfile (hd0,msdos1,gpt1)/grub/grub.cfg to get an actual boot-menu with 30 items, but selecting the last (and default?) of these, Cix Sky1 on Orion O6 USB boot only (Device Tree), throws back several errors and returns me to the prompt.
Editing this entry and inserting the correct paths finally allows me to boot - but then I get:
Booting a command list
linux: kernel file size: 33208832, file (hd0,msdos1,gpt1)/image
linux: kernel numpages: 810840d0000
linux: kernel @ 0x7f5c64000le_bypass=
linux: loaded=1
EFI stub: Booting Linux Kernel...
EFI stub: EFI_RNG_PROTOCOL unavailable
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services...
I/TC: Secondary CPU 0 initializing
I/TC: Secondary CPU 0 switching to normal world boot
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
NOTICE: Send CMD: 0x82000002
[ 3.468864] [pid:1,cpu5,swapper/0]<rdr>exception_info is [],len is [0]
[ 3.475388] [pid:1,cpu5,swapper/0]<rdr>rdr_hisiap_dump modid[80000002],etype[60],coreid[1], log_path[(null)]
[ 3.485205] [pid:1,cpu5,swapper/0]<rdr>[rdr_hisiap_dump], hisi_trace_hook_uninstall start!
[ 3.493459] [pid:1,cpu5,swapper/0]<rdr>rdr_hisiap_dump log_path []
[ 3.499629] [pid:1,cpu5,swapper/0]<rdr>[rdr_hisiap_dump], regs_dump start!
[ 3.506493] [pid:1,cpu5,swapper/0]<rdr>[rdr_hisiap_dump], last_task_stack_dump start!
[ 3.514312] [pid:1,cpu5,swapper/0]<rdr>[rdr_hisiap_dump], save_module_dump_mem start!
[ 3.522130] [pid:1,cpu5,swapper/0]<rdr>[save_module_dump_mem], enter
[ 3.528476] [pid:1,cpu5,swapper/0]<rdr>[save_module_dump_mem], exit
[ 3.534732] [pid:1,cpu5,swapper/0]<rdr>=================struct ap_eh_root================
[ 3.534734] [pid:1,cpu5,swapper/0]<rdr>[print_debug_info], dump_magic [0x19283746]
[ 3.550456] [pid:1,cpu5,swapper/0]<rdr>[print_debug_info], version []
[ 3.556888] [pid:1,cpu5,swapper/0]<rdr>[print_debug_info], modid [0x80000002]
[ 3.564012] [pid:1,cpu5,swapper/0]<rdr>[print_debug_info], e_exce_type [0x60],
[ 3.571223] [pid:1,cpu5,swapper/0]<rdr>[print_debug_info], e_exce_subtype [0x0],
[ 3.578608] [pid:1,cpu5,swapper/0]<rdr>[print_debug_info], coreid [0x1]
[ 3.585212] [pid:1,cpu5,swapper/0]<rdr>[print_debug_info], slice [0]
[ 3.591555] [pid:1,cpu5,swapper/0]<rdr>[print_debug_info], enter_times [0x1]
[ 3.598592] [pid:1,cpu5,swapper/0]<rdr>[print_debug_info], num_reg_regions [0x0]
[ 3.605977] [pid:1,cpu5,swapper/0]<rdr>[rdr_hisiap_dump], exit!
[ 3.611885] [pid:1,cpu5,swapper/0]<rdr>rdr_dump_done: modid:[0x80000002], coreid:[0x1]
[ 3.619791] [pid:1,cpu5,swapper/0]<rdr>rdr_dump_done current mask:[0x1]
[ 3.626395] [pid:1,cpu5,swapper/0]<rdr>dump module data [AP] end!
[ 3.632477] [pid:1,cpu5,swapper/0]<rdr>Skip module core [0x1]. rdr_notify_module_dump:461
[ 3.640647] [pid:1,cpu5,swapper/0]<rdr>p_module_ops->s_core_id is [0x1]
[ 3.647250] [pid:1,cpu5,swapper/0]<rdr>reboot priority[Now], need reboot flag[false] syserr list[empty], coreid mask[0x1]
[ 3.658194] [pid:1,cpu5,swapper/0]<rdr>reboot now!
[ 3.662974] [pid:1,cpu5,swapper/0]<rdr>rdr_hisiap_reset start
[ 3.680134] [pid:1,cpu5,swapper/0]<rdr>rdr_hisiap_reset end
[ 3.685703] [pid:1,cpu5,swapper/0]plat_pm_system_reset_comm cmd is null
[ 3.692308] [pid:1,cpu5,swapper/0]<dst>[set_reboot_reason]: reboot reason is already set
NOTICE: BL2: v2.7(debug):Beta_2.0.3_release
NOTICE: BL2: Built : 20:04:34, Jan 15 2025
CRYPTO_LITE TOP_STAT_CFG0_STAT:0x70018c63
CRYPTO_LITE Wait SW initialization done!
CRYPTO_LITE Software initialization done!
CRYPTO_LITE Current host ID: 1
CRYPTO_LITE RN_POOL is: Secure
CRYPTO_LITE ACA is: Secure
CRYPTO_LITE HASH is: Secure
CRYPTO_LITE SCA is: Secure
CRYPTO_LITE ACA SRAM size: 8192 Bytes
CRYPTO_LITE ACA CQ depth: 8
CRYPTO_LITE HASH CQ depth: 8
CRYPTO_LITE SCA CQ depth: 8
CRYPTO_LITE HASH long ctx number: 4
CRYPTO_LITE HASH short ctx number: 4
CRYPTO_LITE SCA long ctx number: 4
CRYPTO_LITE SCA short ctx number: 4
CRYPTO_LITE OTP device initial value: 1
CRYPTO_LITE OTP shadow registers save to AO
CRYPTO_LITE OTP device: NOT exist
CRYPTO_LITE TRNG internal source: Exist
CRYPTO_LITE CE Version: EAC REL r3p1
INFO: Using crypto library 'CIX SEC'
INFO: BL2: Doing platform setup
INFO: Configuring TrustZone Controller
INFO: Total 2 regions set.
INFO: BL2: Loading image id 3
INFO: Loading image id=7 at address 0x80200000
INFO: pb.tfabde:0
INFO: Flash load BL3X!
INFO: Image id=7 loaded: 0x80200000 - 0x80200650
INFO: SE lc: 7, sec: 1, img_id: 7
INFO: copy ROTPK from DDR
INFO: copy done
INFO: rsa len: 384
padding_type:3
rsa bits:5
CRYPTO_LITE RSA verify pass, pkcs2v1
INFO: md_alg: 6
INFO: hash_len: 32
INFO: Loading image id=9 at address 0x80200000
INFO: pb.tfabde:0
INFO: Image id=9 loaded: 0x80200000 - 0x8020065a
INFO: SE lc: 7, sec: 1, img_id: 9
INFO: rsa len: 384
padding_type:3
rsa bits:5
INFO: Loading image id=13 at address 0x80200000
INFO: pb.tfabde:0
INFO: Image id=13 loaded: 0x80200000 - 0x80200530
INFO: SE lc: 7, sec: 1, img_id: 13
INFO: rsa len: 384
padding_type:3
rsa bits:5
INFO: Loading image id=3 at address 0x80200000
INFO: pb.tfabde:0
INFO: Image id=3 loaded: 0x80200000 - 0x8021961d
INFO: SE lc: 7, sec: 1, img_id: 3
INFO: BL2: Loading image id 4
INFO: Loading image id=10 at address 0x80500000
INFO: pb.tfabde:0
INFO: Image id=10 loaded: 0x80500000 - 0x80500668
INFO: SE lc: 7, sec: 1, img_id: 10
INFO: rsa len: 384
padding_type:3
rsa bits:5
INFO: Loading image id=14 at address 0x80500000
INFO: pb.tfabde:0
INFO: Image id=14 loaded: 0x80500000 - 0x805005ce
INFO: SE lc: 7, sec: 1, img_id: 14
INFO: rsa len: 384
padding_type:3
rsa bits:5
INFO: Loading image id=4 at address 0x80500000
INFO: pb.tfabde:0
INFO: Image id=4 loaded: 0x80500000 - 0x805cd8d8
INFO: SE lc: 7, sec: 1, img_id: 4
INFO: BL2: Loading image id 5
INFO: Loading image id=36 at address 0x84400000
INFO: pb.tfabde:0
INFO: Image id=36 loaded: 0x84400000 - 0x8440063a
INFO: SE lc: 7, sec: 1, img_id: 36
INFO: copy done
INFO: rsa len: 384
padding_type:3
rsa bits:5
INFO: md_alg: 6
INFO: hash_len: 32
INFO: Loading image id=11 at address 0x84400000
INFO: pb.tfabde:0
INFO: Image id=11 loaded: 0x84400000 - 0x8440066b
INFO: SE lc: 7, sec: 1, img_id: 11
INFO: rsa len: 384
padding_type:3
rsa bits:5
INFO: Loading image id=15 at address 0x84400000
INFO: pb.tfabde:0
INFO: Image id=15 loaded: 0x84400000 - 0x84400541
INFO: SE lc: 7, sec: 1, img_id: 15
INFO: rsa len: 384
padding_type:3
rsa bits:5
INFO: Loading image id=5 at address 0x84400000
INFO: pb.tfabde:0
INFO: Image id=5 loaded: 0x84400000 - 0x84600000
INFO: SE lc: 7, sec: 1, img_id: 5
NOTICE: BL2: Booting BL31
INFO: Entry point address = 0x80200000
INFO: SPSR = 0x3cd
INFO: Start sky1 scmi server!
NOTICE: BL31: v2.7(debug):Beta_2.0.3_release
NOTICE: BL31: Built : 20:04:34, Jan 15 2025
INFO: boot_core_index 10
INFO: cpu mask 0xa000
INFO: GICv4 without legacy support detected.
INFO: ARM GICv4 driver initialized in EL3
INFO: Maximum SPI INTID supported: 543
INFO: drv_mbox_init
INFO: Send CMD: ECHO Request
NOTICE: Send CMD: 0x82000001
INFO: Got Echo RSP, Mbox channel is ready...
INFO: plat_cix_scmi_setup
INFO: SCMI driver initialized
INFO: ###########ni700-qos setting###########################
INFO: [MMHUB_CSI_SLV0]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_CSI_SLV1]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU0_AFBC_SLV]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU0_SLV0]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU0_SLV1]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU1_AFBC_SLV]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU1_SLV0]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU1_SLV1]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU2_AFBC_SLV]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU2_SLV0]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU2_SLV1]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU3_AFBC_SLV]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU3_SLV0]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU3_SLV1]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU4_AFBC_SLV]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU4_SLV0]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_DPU4_SLV1]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_ISP_AFBC_SLV]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_ISP_SLV0]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_ISP_SLV1]:override--1 read_qos--0f write_qos--0f
INFO: [MMHUB_NPU_SLV0]:override--1 read_qos--0d write_qos--0d
INFO: [MMHUB_NPU_SLV1]:override--1 read_qos--0d write_qos--0d
INFO: [MMHUB_VPU_SLV0]:override--1 read_qos--0d write_qos--0d
INFO: [MMHUB_VPU_SLV1]:override--1 read_qos--0d write_qos--0d
INFO: [SYSHUB_AUIDO_SLV]:override--1 read_qos--0f write_qos--0f
INFO: [SYSHUB_USB2_0_SLV]:override--1 read_qos--08 write_qos--08
INFO: [SYSHUB_USB2_1_SLV]:override--1 read_qos--08 write_qos--08
INFO: [SYSHUB_USB2_2_SLV]:override--1 read_qos--08 write_qos--08
INFO: [SYSHUB_USB2_3_SLV]:override--1 read_qos--0f write_qos--0f
INFO: [SYSHUB_USB3_0_SLV]:override--1 read_qos--08 write_qos--08
INFO: [SYSHUB_USB3_1_SLV]:override--1 read_qos--08 write_qos--08
INFO: [SYSHUB_USBC_0_SLV]:override--1 read_qos--08 write_qos--08
INFO: [SYSHUB_USBC_1_SLV]:override--1 read_qos--08 write_qos--08
INFO: [SYSHUB_USBC_2_SLV]:override--1 read_qos--08 write_qos--08
INFO: [SYSHUB_USBC_DRD_SLV]:override--1 read_qos--08 write_qos--08
INFO: ######################################################
INFO: ###########ci700-qos setting###########################
INFO: [CI700_RNF0]:override--1 read_qos--0d write_qos--0d
INFO: [CI700_RNF1]:override--1 read_qos--0d write_qos--0d
INFO: [CI700_RNF2]:override--1 read_qos--0d write_qos--0d
INFO: [CI700_RNF3]:override--1 read_qos--0d write_qos--0d
INFO: [CI700_GPU_RNI64_S0]:override[r-w]--[1-1] read_qos--0b write_qos--0b
INFO: [CI700_GPU_RNI64_S1]:override[r-w]--[1-1] read_qos--0b write_qos--0b
INFO: [CI700_GPU_RNI72_S0]:override[r-w]--[1-1] read_qos--0b write_qos--0b
INFO: [CI700_GPU_RNI72_S1]:override[r-w]--[1-1] read_qos--0b write_qos--0b
INFO: [CI700_PCIE]:override[r-w]--[1-1] read_qos--08 write_qos--08
INFO: [CI700_SYSHUB_SMMU]:override[r-w]--[1-1] read_qos--0f write_qos--0f
INFO: [CI700_DFD_TMC]:override[r-w]--[1-1] read_qos--0f write_qos--0f
INFO: [CI700_MMHUB_SMMU]:override[r-w]--[1-1] read_qos--0f write_qos--0f
INFO: [CI700_PCIEHUB_SMMU]:override[r-w]--[1-1] read_qos--0f write_qos--0f
INFO: cix_qspi_init start...
INFO: cix_qspi_init end...
INFO: BL31: Initialising Exception Handling Framework
INFO: last reboot reason:0x60
INFO: BL31: cortex_hunter: CPU workaround for cve_2022_23960 was applied
INFO: SDEI platform setup
INFO: BL31: Initializing BL32
E/TC:10 console_init:108 Cix uart register successful
I/TC:
I/TC: OP-TEE version: Beta_2.0.3_release #1 Wed, 15 Jan 2025 20:08:15 +0800 aarch64
I/TC: OP-TEE cix version: Beta_2.0.3_release-3.17-0af95526e956
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
MBEDTLS_CORE host[1] waits sw_init_done...MBEDTLS_CORE [DONE]
MBEDTLS_CORE HASH driver init success!
MBEDTLS_CORE SCA driver init success!
MBEDTLS_CORE SRAM Pool Base: 0x80000000, size: 0x2000, alignment: 0x10
MBEDTLS_CORE ACA driver init success!
E/TC:10 00 tee_otp_get_hw_unique_key:123 Get hw key:
I/TC: Primary CPU switching to normal world boot
INFO: Entry point address = 0x84400000
INFO: SPSR = 0x3c9
[176.241] [UEFI] E3C1 XspiInitDxeStart
[176.242] [UEFI] E400 XspiInitDxeEnd
[176.331] [UEFI] E2C1 PcieInitDxeStart
Root Port 0 Link up fail
[176.532] [UEFI] E300 PcieInitDxeEnd
One display device is found on typec port1!
Update Platform Config Param GopDisplayPort=0x1
total 3 modes (current pixel clock 54350, width 3440, height 1440)
… at which point the machine reboots and the next output is:
Tianocore/EDK2 firmware version 0.2.2-1
Press ESCAPE for boot options
I’ll note that I’m providing USB-C PD power on USBC0, I have a monitor plugged in by HDMI but it can’t see any signal, NIC0 is plugged-in, and I’ve tried the USB boot drive in both the top USB2.0 and USB3.0 ports.
Any suggestions for what I’ve missed or done wrong?
