I really need to be rigorous when I post on this forum – this forum is trainning me to be a good tech writer now, haha.
I do not have eMMC, and since I have the M.2 NVME extender I use a shorter ribbon, and the case that I bought really forces me to pay attention if I left a sdcard in the slot. So, no SDCard here, that’s for sure. When I was trying to flash SPI, I only have SDcard attached; now that I have flashed SPI, I only have nvme inserted to the Rock Pi.
with NVME being the only medium connected to the ROCK, it’s easy for me to tell what can be booted from nvme–
Debian Stretch downloaded from wiki.radxa.com – this one for sure works
Community image ARBIAN based on stretch – no
Armbian_5.90_Rockpi-4b_Debian_buster_default_4.4.182_desktop - no
I have not tried Ubuntu or Android or LibreElec, etc. I only care about Debian Desktop use.
I see. Well, I’m not really sure what the issue is. My guess is that the boot loader tries to load a kernel that is not there. I.e. there kernel in the image/boot config is named differently than the kernel contained in the image. But I’m not sure about this; at this point it is only a guess.
“the boot loader tries to load a kernel that is not there. I.e. there kernel in the image/boot config is named differently than the kernel contained in the image”
This is what I’m trying to figure out – is there a way to upgrade the kernel in Debian Stretch to Debian Buster? Is there a directory that holds the config file so I just need to copy that file into the new kernel folder and then enjoy the upgraded Debian desktop?
Thank you.
…and here’s my extreme passive cooling scheme for my Rock Pi 4A. Happy Summer Day!
Well the easiest way would be to connect the serial debug console and watch the output of the boot loader
But I guess if you had a USB-serial adapter you would have already done that.
If you have u-boot running from SPI, it should boot any distribution which has a valid partition table since u-boot use distro_boot to scan all partitions.
To be exact, on booting of a freshly echered Debian Stretch, I opened a terminal and typed:
$ export DISTRO=stretch-testing
$ echo “deb http://apt.radxa.com/$DISTRO/ stretch main” | sudo tee /etc/apt/sources.list.d/apt-radxa-com.list
$ wget -O - apt.radxa.com/$DISTRO/public.key | sudo apt-key add -
$ sudo apt-get update && sudo apt-get upgrade
$ sudo apt-get install -y rockchip-fstab
$ sudo apt-get install -y rockchip-overlay
$ sudo apt-get install -y rockpi4-dtbo
$ sudo apt-get install -y linux-4.4-latest # Will update kernel
$ sudo apt-get install -y rockpi4b-rk-u-boot-latest
Then I installed nano and:
$ sudo nano /boot/hw_intfc.conf
I make sure the file is saved with the following settings:
intfc:uart4=off
intfc:spi1=on
intfc:dtoverlay=spi1-flash
Then I updated bootloader:
$ cd /usr/local/sbin/
$ ls
I see four .sh files listed
$ ./rockpi4b_update_bootloader.sh
Then I reboot, and open the terminal and type:
$ sudo /usr/local/sbin/rockpi4b_write_spi_flash.sh
Then YES and I saw the machine running, writing over blocks of data for a few minutes.
After it’s done I shutdown the Rock Pi, remove the SD card, and connect the nvme that I have the official Debian Stretch.
Then I power on the Rock PI and I see Debian Strech running not very smoothly.
If I put on the nvme the official Armbian based on Buster downloaded from here: https://www.armbian.com/rock-pi-4/
The Rock Pi does NOT boot
If I put on the nvme the Armbian based on Stretch from Radxa, the rock pi does not boot.
This is all I know. If I’m not booting from SPI then I’m booting directly from nvme with deiban strech on? If I’m booting from SPI then why Armbian on nvme is not booting? What did I do wrong trying to flash SPI?
Does this have anything to do with the .sh says Rockpi4b and my board is rock pi 4A?
Hah! Why didn’t you tell me that boot can be debugged by console earlier?=)
Here is my boot log. https://pastebin.com/QejZ3PZ9
I’ll try to figure out why u-boot cannot load kernel, but maybe you have any ideas?
The same thing.
What I did:
gunzip -c rockpi4b-ubuntu-bionic-minimal-20190104_2101-gpt.img.gz | dd of=/dev/nvme0n1
What I got: https://pastebin.com/FUA8ngH8
Is your disk samsung evo? Is the disk old or very new?
I am very sorry to tell you that, we have the same issue for one of the old samsung evo 960 in the office. Other newer disks works fine with the same image. The samsung evo 960 disk works if we use it as data disk and formats as ext4 partition but there is some blocks corrupted if we do a full disk read/write.
This is something we haven’t found the reason and probably it will not be fixed in short time. I suggest you try another m.2 nvme disk.
I got a Rock Pi 4B with mounted SPI flash, big heatsink and NVMe extension last Saturday (13/July) from ALLNET China. The version printed on the board is 1.3. I followed the steps using uSD card as specified in https://wiki.radxa.com/Rockpi4/Linux_system_runs_on_M.2_NVME_SSD to write the u-boot to SPI flash without success. I simply cannot get the /dev/mtd0 after reboot. I also tried using the https://wiki.radxa.com/Rockpi4/dev/spi-install to write the u-boot image via USB OTG. It seems that the write is successful and I can see a red LED flashing alongside the always lit green LED when I try to boot the Kingston A1000 NVMe without the uSD card. However the boot was not successful. I am using Ubuntu Server for the NVMe image. Does anyone has a chance to successfully boot Ubuntu Server on the NVMe along. Any direction or help is appreciated.
