I am pretty new with Rock 3A and trying to flash it to make it working with nvme boot
I follow the instructions give in https://wiki.radxa.com/Rock3/install/spi
but it fails everytime
Do you have any experience with this?
Hi Rasa,
the way it worked for me was by installation of the ARMBIAN system onto a separate µSD card, booting the system from this and using “armbian-install” tool to install the boot-loader to MTD flash (setup point 7).
After that I took a fresh NVMe (in an external case) and installed armbian onto (again) by using “balena etcher”. This ensures that there is a valid boot-partition (FAT16) and an ext4 partition on the NVMe and it should boot then correctly without the µSD card.
If you need more specific information, just give me a call ![]()
Hey @Hans did you do something special on this ?
I’m trying to do the same with armbian 23.02, but at the end the nvme drive can’t boot alone. I edit the armbianEnv.txt and the fstab to adapt the drive to use (my /boot and root come from the nvme) :
root@rock-3a:~# df -h
Filesystem Size Used Avail Use% Mounted on
tmpfs 199M 8.5M 190M 5% /run
/dev/nvme0n1p2 116G 1.9G 113G 2% /
tmpfs 991M 0 991M 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 991M 0 991M 0% /tmp
/dev/nvme0n1p1 256M 118M 139M 46% /boot
/dev/zram1 47M 1.1M 43M 3% /var/log
tmpfs 199M 0 199M 0% /run/user/0
But at the end rebooting without the initial sdcard doesn’t work…
Did you do something special ?
No, nothing special, except that I had to do the installation TWICE (like described above):
What might be a flaw is that booting from the NVMe does ONLY work if the jumper (on the forefront near the SD-card-slot) for flashing is REMOVED before booting. If the jumper is still set, booting from NVMe is not possible.
Hope that helps.
Hello, thank you for your feedback. I tried exactly the same thing… strange. Do you remember which version of Armbian you used? I’m also going to try to debug the boot with a serial cable, but the one I have doesn’t seem to support the 1500000 baud rate required for the serial connection.
