SPI Ethernet with W5x00 / USR-ES1
Hi folks,
Trying to extend a ROCK PI S with two additional Ethernet interfaces using SPI.
using wiznets w5500lite Module:
here my uEnv.txt:
verbosity=7
fdtfile=rockchip/rk3308-rock-pi-s.dtb
console=ttyS0,1500000n8
overlays=rk3308-spi-spidev
param_spidev_spi_bus=1
param_spidev_spi_cs=0
param_spidev_max_freq=10000000
rootuuid=d99ac41e-e8cc-4c73-a420-e71f15e42042
initrdsize=0x81648d
kernelversion=4.4.143-69-rockchip-g8ccef796d27d
initrdimg=initrd.img-4.4.143-69-rockchip-g8ccef796d27d
kernelimg=vmlinuz-4.4.143-69-rockchip-g8ccef796d27d
=> spidev1.0 is visible unter /dev
=> spidev-check with MISO-MOSI-loop works fine
=> MISO on GPIO3_B2, MOSI on GPIO3_B4, SCK on GPIO3_B3, CS on GPIO3_B5 connected
Still there is no additional eth appearing under ifconfig.
Do I need some kind of special overlay-file like one of the *.dtbos in overlay-folder?
Any one of you guys experienced in extending the Rock PI S with two more ethernets?
Thanks for your help and greets,
M
@feng can you give any advice?
Hi Peter,
appreciate your help!
Any news on this topic?
Best Michael
W5500 real speed is ~15Mbps. If I was in your place, I’d use a powered USB-C hub with built-in RTL8152 & additional RTL8152 dongle(s) into it, with a single power source powering the hub&SBC for simplicity. If you don’t need speed, can use visually identical hub & dongle(s) based on RD9700 that goes up to 12Mbps. Not only will either solution save you the headache, it will also be cheaper and easier to source than SPI W5500 & ENC28J60.
Thanks for your suggestion!
Would do it, if not the main purpose is to integrate everything in a small housing to create a smart device.
The USB-dongles are just too big for the solution and the W5500 is perfect to integrate.
Maybe switching to RPI Zero, there is an existing dtbo-file for W5500. :-/
BTW: speed is not a problem…some laser line data from a ToF sensor
I understand. Good luck - and please let me know if you succeed!
