Hi all
I imagine that my question must seem trivial, but I am trying to decide on which SBC to install a video “box”. Either with an RPi3/4 2GB (but not powerful enough in the end to play all video streams from what I understand) or as I have just discovered since this morning a Radxa Zero 2GB/8GB (more powerful).
My main problem at the moment is to know if there is a plastic box provided for an Radxa Zero like the Raspberry have. I’m afraid to hear no and that you have to make it yourself because I’m neither a handyman (other than in IT), nor I have access to a 3D printer…
A proposition ?
With Adelphity
lnj
Since no one gives me any leads, I answer myself.
I found this kind of solution which consists to order custom prototypes (like from this site, but you have to order minimum 5 and I only need one).
Are there other solutions ?
Acrylic protector for now, unless you can mod some Rpi Zero cases.
Hi Inj, I used some spare screws from a computer case to lift the Zero up then marked where the ports would be in the clear case it came in. Then I took a small drill bit to fashion openings:
At first I used some non-conductive foam to fill the gap but then i picked up some M3x6mm standoffs to lock the Zero in place.
For a relay board in the same project, I picked up some M3 screws, nuts & nylon spacers from the local hardware store to fix it in position.
Hope this helps!
Thank you
! That was exactly what I searched …
I simulated a buy to France (where I live) : including shipping costs about $16 (USD ?)
So my request is answered
Oooooh ! This do it yourself with the parts available in the Mac Gyver’s way I like a lot
. Good idea and thank you too !
Superb @lenainjaune! Happy to be of help
The RPI Zero Flirc case fits perfect on my model, even the USB C cables snap in nicely without any need for sanding/drilling.
