[Solved] Radxa Camera 8M not listed in rsetup on Zero 3W
Hi, I’m trying to setup the 8m-219 with my zero 3w
I’ve installed the latest debian image, run rsetup, updated the latest overlays, and connected the two devices together:
the problem is i dont see [] Enable Radxa Camera 8M 219 on CSI0 listed in the available overlays (as mentioned here Radxa Camera 8M | Radxa Docs)
am I doing something wrong?
any help appreciated - thanks in advance!
Activate this: radxa-zero3-rpi-camera-v2
hi @blondu thanks for the reply - can you please explain what you mean by activate?
should radxa-zero3-rpi-camera-v2 be accessible from terminal?
you should execute sudo rsetup and select image
which is motioned in the page
Thanks @Peter.Wang, I did that however enabling the pi camera v1.3 does not persist.
i select this:
and then reboot, and after checking the selected overlays again, the camera v1.3 is not shown as enabled
Here’s what I see when attempting to view the camera with cheese:
Hi
You should enbale Radxa Camera 8M 219 by rsetup.
Thanks @Alvin, unfortunately the camera is not listed in rsetup
Does that mean the camera’s faulty?
Firstly, dumb mistake, I didn’t realise the space key actually selected/toggled items in the overlays menu. Pressing space on the highlighted overlay, causes it to be selected (as shown by *)
Once I did that on camera v1.3, I rebooted the device. The camera didn’t work.
I then tried camera v2, rebooted, and it worked. The Radax Camera 8M 219 seems to be recognized as a rasberrypi camera v2
Thanks for all who helped here
