There is an error that says “1153 non-manifold edges”, thinking I may import into meshmixer and try autofix, but I wanted to ask here.
That’s only on the vesa stl btw, the other is fine.
I’m also having problems slicing the top. Half of the model appears to be slightly higher which is causing the slicer to think there is no first layer there:
I’m thinking about remixing it at the back of a screen case also 3d printed(there are good deals on 7" ips screens rn from china like $35) not sure the dsi/touch screens are supported though they list most other SBCs as supported
I really like the PicoITX format and wish you could buy a flat IO cutout rather than press in just stick so it makes ‘any case’ really easy, 3d printed or old school sledge hammer, chisel and superglue…
Small problems with the Rock5B+
The case holes only are correct on the front plate, so 2xHDMI out, USB, Ethernet, Audio and USB-C Power are OK.
MicroSD card, USB-C Debug port and HDMI Input are not correct on the current Rock5B case.
MicroHDMI is on the location for USB-C Debub port
HDMI In has no hole, MicroSD Card does not align as on the 5B+ it is located on the side, below the HDMI Input at that.
Also, no bottom access for SIM card slot.
