Does anyone happen to know how much power the radxa zero consumes after it is shut down? As in using the Power off command or shutdown?
I have a project using a power bank with a pi 4, and in a shutdown state, it drains so little power, the pack shuts off, which I like. I tried a rock pi s, and it draws too much power to allow the power bank to shut off. I’m hoping the zero will behave like the pi 4.
The pi4 will go down to approx 3mA if you sudo poweroff or sudo shutdown -P and you have to power cycle to wake up the pmic.
If you look at the power section the pmic MP1601/MP1605 has an enable but not on all whilst RockpiS seems to just use a simple RC delay without enable for all.
So yeah likely it could be less than the RockpiS, but maybe not as low as the Pi4 as it has a global enable?
