Setup and run GPU Benchmark on Orion O6
OS Environment
Debian12
GPU Driver
Latest GO from https://developer.cixtech.com/
box64
su root
wget https://ryanfortner.github.io/box64-debs/box64.list -O /etc/apt/sources.list.d/box64.list
wget -qO- https://ryanfortner.github.io/box64-debs/KEY.gpg | sudo gpg --dearmor -o /etc/apt/trusted.gpg.d/box64-debs-archive-keyring.gpg
apt-get update
apt-get install box64
OpenGL Benchmark
Unigne Heaven
  • Download the Linux version of Heaven from https://benchmark.unigine.com/heaven .
  • Install Heaven by running the command ./Unigine_Heaven-4.0.run.
  • Since Heaven only has an x86 version, it needs to be launched with box64 heaven.
  • The following screenshot shows the result in 1080p window mode.
Unigne Valley
  • Download the Linux version of Valley from https://benchmark.unigine.com/valley.
  • Install Valley by running the command ./Unigine_Valley-1.0.run.
  • Since Valley only has an x86 version, it needs to be launched with box64 valley.
Vulkan Benchmark
FurMark2 2.8.0
  • Download the ARM version of FurMark2 from https://geeks3d.com/dl/get/806.
  • Unzip FurMark_2.8.0.0_arm64.7z.
  • Launch ./FurMark_GUI.
  • Select FurMark(VK) under Graphics Test: .
GravityMark 1.89
  • Download the ARM version of GravityMark from https://tellusim.com/download/GravityMark_1.89_arm64.run.
  • Install GravityMark by running the command GravityMark_1.89_arm64.run.
  • Run the GravityMark vukan fullscreen benchmark using the command ./run_fullscreen_vk.sh.
  • The following screenshot shows the result of fullscreen mode.
