Selecting 'libmraa' instead of 'libmraa-rockpi4'
Hi
I’m trying to install libmraa-rockpi4 to get the PoE HAT fan working.
Unfortunately I get stuck as python3.7 isn’t available…
linaro@linaro-alip:~$ sudo apt install libmraa-rockpi4
Reading package lists… Done
Building dependency tree
Note, selecting ‘libmraa’ instead of ‘libmraa-rockpi4’
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
libmraa : Depends: python3.7 but it is not installable
Depends: libpython3.7 but it is not installable
E: Unable to correct problems, you have held broken packages.
Should I get python3.7 installed or should I try to get libmraa-rockpi4 ?
The dependency of the package is broken.
We might need to take a look. @Stephen
same issue here, reports to try and install python3.5 with 3.8 installed…
