Dear community,
Does anyone has tested the work of Rock Pi X with the Official Raspberry Pi 7’’ Touchscreen under Windows 10? Is everything works fine?
Best Regards,
Ivan
Dear community,
Best Regards,
Ivan
Im using this one, and it works as expected. i have not tried the “Official” one though.
https://www.amazon.com/gp/product/B07L6WT77H/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
I’m using a similar one too, but I think that the “Official” connects to the Raspberry Pi through a ribbon cable, not via USB+HDMI.
The Rock Pi X indeed has a display connector for a ribbon cable (CPU side, beside the microSD socket), the question is whether it works under Windows or Linux.
Thank you for your replies.
Yes I meant that connects with the ribbon to the main board.
I read Raspberry Pi official touch screen description more carefully and understood, that even if it working fine, it is only 800X480, that can cut me from using a lot of software with minimum requirements of 800X600, so I probably gonna use one with HDMI plus USB connection.
Thank you again.
Best Regards.
I am using the same one as Phil, touch works out of the box with windows 10 resolution is very sharp and clear @ 1024x600 and it connects to the board with a standard HDMI connector on one end that turns into a ribbon style connector for the board side connection . (That hybrid cable comes with the screen)
This leaves you with a hdmi out connector on the board that can be used to connect to to an out board monitor or t.v.
And dont pay $85 for this screen, i see them on ebay or AliExpress more in the range of $40
