Hi everyone,
I need help with my Radxa Penta SATA HAT setup.
Hardware:
- Raspberry Pi 5, Debian Bookworm (6.12 kernel)
- Penta SATA HAT (bottom board)
- SATA HAT Top Board V1.2 (with OLED and fan button)
- 12V PSU connected
- 4 × SATA SSD installed
- I2C detected: address 0x3c (correct OLED response)
- Fan control works, button works
- OLED display remains completely black, zero backlight
Software:
- rockpi-penta package 0.2.2 installed from Radxa repo
- systemd service running without errors
- luma.oled installed and test scripts run without visible output
- Tried rotating, contrast, multiple SSD1306 and SH1106 drivers → no display output
- i2cdump shows valid STM32 response (not 0xff), communication is OK
What I suspect:
- The Top Board V1.2 uses a new MCU firmware which might not be compatible with rockpi-penta 0.2.2
- The MCU firmware for the top board isn’t available online (older firmwares 404)
- Maybe Raspberry Pi 5 needs a special config or overlay?
Questions:
Is there a firmware update required for the Top Board V1.2 OLED?
Where can I download the correct top-hat-mcu.bin firmware?
Does rockpi-penta software fully support Raspberry Pi 5 today?
Any example config.txt or rockpi-penta.conf for Pi 5?
Here are pictures of my setup:
(then attach the two photos)
Thanks in advance! We are very close — the display must be working, just missing the right firmware or config.
