hi I’m making a case for my quad sata and penta hat
i want to replace 40mm fan it comes with and put 2 DC Brushless Cooling Fan 60 x 60 x 15mm 60mm 6015 7 blades 5V 3pin Connector in each case
the info on each fan:
MODEL: 6015S
- size: 60mm (L) x 60mm (W) x 15mm (H)
- Rated Voltage: 5V
- Rated Current: 0.20A
- Rated Power: 1W
- Rated Speed: 7000RPM
- Noise Level: 26dB(A)
- Air Flow: 7CFM
- Connector: 3pin/3wire
what i would like to know is this feasible can the top hat handle it
