I’m following the Windows instructions. I’ve loaded up the factory-loader.img, but when I click “run”, all I get is the “start run” message, the run and erase buttons become disabled. It never goes any further than that.
Thanks for the help, I originally had it plugged into a usb hub, so I grabbed a different cable and plugged it directly into the computer.
The first time I got it to run, and it did get to the “run done”, but I got several crash messages immediately afterwards (Isusb.exe has stopped working) and since then I can’t get it to load. “Not detected” comes up instead of “Maskrom mode”. I unplugged it and started it up while I have the Boot Helper program running, and I got the crash message again as it powered up.
I’m very need to this, I have a few Raspberry pi’s , but I only have used them with an SD card, so I’m not familiar with this procedure.
thanks again, I’m not familiar with python, something I’ve been wanting to get around to.
I have a laptop running windows 10, I’ll try it on that later today. Maybe I’ll have better luck there. I have another PC that I can try, I just have nowhere to set it up without taking my production computer offline, so if the laptop doesn’t work, I’ll see if I can try that over the weekend. I also have 2 macs, but I’d prefer not to use those as our Mac IT guy is more strict with loading software on those.
It worked on the laptop running Windows 10. It’s an old machine, so it’s excruciatingly slow, but i got through all steps except for erasing the memory, but I was able to load Armbian, and I’m getting the startup screen now, it’s taking a while to load, so I don’t know if it’s running properly, but at least the first steps worked.
Hello all,
I am trying to install Debian OS on eMMC. RKDevTool is detected MASKROM device however, it comes up with Download Boot Fail. I tried RZ USB Boot Hlper and it wont detect the device as shown below. I am not using an microSD or a HDMI output to see what is going on on the screen. When I did plug in HDMI output, the screen is blank. So none of the troubleshooting guide can be used.
