Is it possible to run docker on radxa ubuntu server image (rockpin10bc_ubuntu_bionic_server_arm64_20210125_2038-gpt.img)? When running i have this error:
root@rockpin10bc:~# docker run hello-world
Unable to find image 'hello-world:latest' locally
latest: Pulling from library/hello-world
256ab8fe8778: Pull complete
Digest: sha256:5122f6204b6a3596e048758cabba3c46b1c937a46b5be6225b835d091b90e46c
Status: Downloaded newer image for hello-world:latest
docker: Error response from daemon: failed to create endpoint flamboyant_carver on network bridge: failed to add the host (vetha9947bb) <=> sandbox (vetha2b5a71) pair interfaces: operation not supported.
ERRO[0004] error waiting for container: context canceled
Distributor ID: Ubuntu
Description: Ubuntu 20.04.2 LTS
Release: 20.04
Codename: focal
IP: 10.0.0.100 172.17.0.1 2002:5fa0:2716:1::1001
[0][19:28][root@rock][~] $ docker run hello-world
Hello from Docker!
This message shows that your installation appears to be working correctly.
To generate this message, Docker took the following steps:
1. The Docker client contacted the Docker daemon.
2. The Docker daemon pulled the "hello-world" image from the Docker Hub.
(arm64v8)
3. The Docker daemon created a new container from that image which runs the
executable that produces the output you are currently reading.
4. The Docker daemon streamed that output to the Docker client, which sent it
to your terminal.
To try something more ambitious, you can run an Ubuntu container with:
$ docker run -it ubuntu bash
Share images, automate workflows, and more with a free Docker ID:
https://hub.docker.com/
For more examples and ideas, visit:
https://docs.docker.com/get-started/
No problem on my side.
Linux rock 4.4.154-110-rockchip-gcef30e88a9f5 #1 SMP Mon Jun 22 07:37:10 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux
We have fixed this. Please upgrade the kernel to version 4.4.167-20.
root@rockpin10bc:/home/rock# uname -a
Linux rockpin10bc 4.4.167-20-rockchip-g5f826bc48b1e #1 SMP Mon Jun 7 03:46:31 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
root@rockpin10bc:/home/rock# docker run hello-world
Hello from Docker!
(arm64v8)
to your terminal.
