It’s librga issue with your kernel version. My board has 2GB RAM. I guess you have > 4GB RAM?
Try with:
io-mode=mmap
Try with:
io-mode=mmap
Yep, this is the 4GB version.
Seems to hit the same error:
radxa@radxa-zero3:~/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.18.4/build/examples$ sudo ./test-launch "( v4l2src device=/dev/video0 io-mode=mmap ! video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 ! mpph264enc ! rtph264pay name=pay0 pt=96 )"
stream ready at rtsp://127.0.0.1:8554/test
rga_api version 1.3.1_[11] (RGA is compiling with meson base: $PRODUCT_BASE)
RgaBlit(1356) RGA_BLIT fail: Invalid argument RgaBlit(1357) RGA_BLIT fail: Invalid argument
fd-vir-phy-hnd-format[0, 0xffffb0edf0a0, (nil), (nil), 0]
rect[0, 0, 1920, 1080, 1920, 1088, 2560, 0]
f-blend-size-rotation-col-log-mmu[0, 0, 0, 0, 0, 0, 1]
fd-vir-phy-hnd-format[26, (nil), (nil), (nil), 0]
This output the user patamaters when rga call blit fail
fd-vir-phy-hnd-format[0, 0xffff9c016490, (nil), (nil), 0]
fd-vir-phy-hnd-format[35, (nil), (nil), (nil), 0]
We seen this before. It is related to the libRGA on the Radxa Zero3E, as @avaf mentioned. BTW, the amount of RAM doesn’t matter.
See also: RGA crashes on Zero 3E, not with Zero 3W
