I had time today to test the gstreamer rtsp server on my 3W.
The test here re-used an old Rock 3A rootfs i tuned some time ago, so i can say it is fully compatible with rk3568, the missing bit is the NPU.
1. Environment
Camera IMX219 120º - Streaming 1920x1080
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.3 LTS
Release: 22.04
Codename: jammy
ifconfig
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 102 bytes 8652 (8.6 KB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 102 bytes 8652 (8.6 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.254.232 netmask 255.255.0.0 broadcast 192.168.255.255
inet6 2804:7f4:322a:3049:f886:275c:2f76:6a9f prefixlen 64 scopeid 0x0<global>
inet6 2804:7f4:322a:3049:7995:b2b0:b9cc:1299 prefixlen 64 scopeid 0x0<global>
inet6 fe80::2ebb:ede:92fd:c7b prefixlen 64 scopeid 0x20<link>
inet6 2804:7f4:322a:3049:7d08:5033:c30e:1775 prefixlen 64 scopeid 0x0<global>
inet6 2804:7f4:322a:3049:ba1a:8e12:c11e:fc4a prefixlen 64 scopeid 0x0<global>
inet6 fe80::6b09:b810:c4ca:ebce prefixlen 64 scopeid 0x20<link>
ether 98:03:cf:c6:e5:9c txqueuelen 1000 (Ethernet)
RX packets 177717 bytes 12985990 (12.9 MB)
TX packets 382347 bytes 552496728 (552.4 MB)
Linux rzero-3w 5.10.160-imx219 #2 SMP Sun Jan 28 11:45:52 -03 2024 aarch64 aarch64 aarch64 GNU/Linux
Ambient Temp: 28ºC
Board Temp (idle):
cat /sys/devices/virtual/thermal/thermal_zone0/temp
58333
2. Minimum requirements
Kernel, RGA, MPP, gstreamer, and rockchip media must be up-to-date.
gst-inspect-1.0|grep -i rock
rkisp: rkisp: Gstreamer Plugin For Rockchip ISP Source
rockchipmpp: mpph264enc: Rockchip Mpp H264 Encoder
rockchipmpp: mpph265enc: Rockchip Mpp H265 Encoder
rockchipmpp: mppjpegdec: Rockchip’s MPP JPEG image decoder
rockchipmpp: mppjpegenc: Rockchip Mpp JPEG Encoder
rockchipmpp: mppvideodec: Rockchip’s MPP video decoder
rockchipmpp: mppvpxalphadecodebin: VP8/VP9 Alpha Decoder
3. Building gstreamer rtsp server
Build:
wget https://gstreamer.freedesktop.org/src/gst-rtsp-server/gst-rtsp-server-1.20.3.tar.xz
tar -xf gst-rtsp-server-1.20.3.tar.xz gst-rtsp-server-1.20.3/
cd gst-rtsp-server-1.20.3/
mkdir build && cd build
meson --prefix=/usr --wrap-mode=nofallback -D buildtype=release -D package-origin=Index of /src/gstreamer -D package-name=“GStreamer 1.20.3” ..
ninja -j4
sudo ninja install
sudo ldconfig
Run:
cd examples/
rock@rzero-3w:~/rockchip/gstreamer/rtsp-server/gst-rtsp-server-1.20.3/build/examples$
sudo ./test-launch “( v4l2src device=/dev/video0 io-mode=dmabuf ! video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 ! mpph264enc ! rtph264pay name=pay0 pt=96 )”
CPU Load and Temperature while running rtsp server after the compilation:
root@rzero-3w:/home/rock# top
top - 13:06:31 up 2:31, 0 users, load average: 2.32, 1.70, 1.00
Tasks: 158 total, 1 running, 157 sleeping, 0 stopped, 0 zombie
%Cpu(s): 9.7 us, 16.7 sy, 0.0 ni, 72.4 id, 0.0 wa, 0.0 hi, 1.2 si, 0.0 st
MiB Mem : 1977.7 total, 1053.8 free, 188.4 used, 735.6 buff/cache
MiB Swap: 0.0 total, 0.0 free, 0.0 used. 1626.6 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
3812 root 20 0 718392 31344 15872 S 66.1 1.5 5:27.60 test-la+
285 root 20 0 1081888 8556 4724 S 21.4 0.4 2:07.06 rkaiq_3+
163 root 39 19 0 0 0 S 7.6 0.0 0:36.02 dmabuf-+
180 root rt 0 0 0 0 S 5.9 0.0 1:22.20 sugov:0
526 root -2 0 0 0 0 S 2.3 0.0 0:13.71 aicwf_b+
527 root -2 0 0 0 0 S 1.6 0.0 0:10.35 aicwf_b+
3940 root 20 0 7392 3208 2620 R 1.3 0.2 0:01.22 top
11 root 20 0 0 0 0 I 1.0 0.0 0:07.10 rcu_sch+
149 root 20 0 0 0 0 S 1.0 0.0 0:05.27 queue_w+
173 root 20 0 0 0 0 I 0.7 0.0 0:01.89 kworker+
192 root -51 0 0 0 0 S 0.7 0.0 0:03.87 irq/29-+
196 root -51 0 0 0 0 S 0.7 0.0 0:02.75 irq/35-+
3951 root 20 0 0 0 0 I 0.7 0.0 0:00.73 kworker+
10 root 20 0 0 0 0 S 0.3 0.0 0:01.41 ksoftir+
32 root 20 0 0 0 0 I 0.3 0.0 0:05.56 kworker+
193 root 20 0 0 0 0 I 0.3 0.0 0:00.79 kworker+
1342 root 20 0 0 0 0 I 0.3 0.0 0:04.17 kworker+
root@rzero-3w:/home/rock# cat /sys/devices/virtual/thermal/thermal_zone0/temp
68125
