The time on my Rock 5B is wrong:
$ timedatectl
Local time: Tue 2023-06-27 01:16:12 UTC
Universal time: Tue 2023-06-27 01:16:12 UTC
RTC time: Tue 2023-06-27 01:16:13
Time zone: UTC (UTC, +0000)
System clock synchronized: no
NTP service: active
RTC in local TZ: no
This is about three days behind the actual date and time.
`timesyncd1 is running, but does not say it has sync’ed:
$ sudo systemctl status systemd-timesyncd
● systemd-timesyncd.service - Network Time Synchronization
Loaded: loaded (/lib/systemd/system/systemd-timesyncd.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2023-06-27 01:05:28 UTC; 12min ago
Docs: man:systemd-timesyncd.service(8)
Main PID: 408 (systemd-timesyn)
Status: "Idle."
Tasks: 2 (limit: 18844)
Memory: 1.1M
CPU: 465ms
CGroup: /system.slice/systemd-timesyncd.service
└─408 /lib/systemd/systemd-timesyncd
Mar 20 14:32:08 stake02 systemd[1]: Starting Network Time Synchronization...
Mar 20 14:32:08 stake02 systemd-timesyncd[408]: System clock time unset or jumped backwards, restoring from recorded timestamp: Tue 2023-06-27 01:05:28 UTC
Jun 27 01:05:28 stake02 systemd[1]: Started Network Time Synchronization.
Jun 27 01:05:33 stake02 systemd-timesyncd[408]: Network configuration changed, trying to establish connection.
Jun 27 01:05:35 stake02 systemd-timesyncd[408]: Network configuration changed, trying to establish connection.
Jun 27 01:05:39 stake02 systemd-timesyncd[408]: Network configuration changed, trying to establish connection.
I have no battery connected for the RTC and was disappointed to learn the board didn’t ship with one. Do I need one if network time is running properly? I will want the time to be correct early in the boot sequence.
How do I get network time sync’ed on boot without using the RTC?
