I’ve tried unplugging them, as well as rebooting and disconnecting all but one. Are there any known compatibility issues with HDDS and the Penta SATA Hat? I’m trying to connect 1 (of 4) of these Seagate Ironwolf HDDs
Thanks Dominik!! I don’t really know how to use dmesg, this is the output:
[ 16.800069] ata1: found unknown device (class 0)
[ 16.800103] ata1: SATA link down (SStatus 0 SControl 310)
[ 16.800120] ata1: limiting SATA link speed to 1.5 Gbps
[ 17.700061] ata1: found unknown device (class 0)
[ 17.700078] ata1: SATA link down (SStatus 0 SControl 310)
[ 17.883766] ata1: limiting SATA link speed to 1.5 Gbps
[ 18.656063] ata1: found unknown device (class 0)
[ 18.656078] ata1: SATA link down (SStatus 0 SControl 310)
[ 18.813226] ata1: limiting SATA link speed to 1.5 Gbps
[ 19.588067] ata1: found unknown device (class 0)
[ 19.588082] ata1: SATA link down (SStatus 0 SControl 310)
[ 19.744131] ata1: limiting SATA link speed to 1.5 Gbps
[ 20.520084] ata1: found unknown device (class 0)
[ 20.520102] ata1: SATA link down (SStatus 0 SControl 310)
[ 20.674007] ata1: limiting SATA link speed to 1.5 Gbps
[ 21.444071] ata1: found unknown device (class 0)
[ 21.444084] ata1: SATA link down (SStatus 0 SControl 310)
[ 21.605080] ata1: limiting SATA link speed to 1.5 Gbps
[ 22.376072] ata1: found unknown device (class 0)
[ 22.376082] ata1: SATA link down (SStatus 0 SControl 310)
[ 22.535315] ata1: limiting SATA link speed to 1.5 Gbps
[ 23.308075] ata1: found unknown device (class 0)
[ 23.308085] ata1: SATA link down (SStatus 0 SControl 310)
[ 23.464828] ata1: limiting SATA link speed to 1.5 Gbps
[ 25.136082] ata1: found unknown device (class 0)
[ 25.136094] ata1: SATA link down (SStatus 0 SControl 310)
[ 25.294724] ata1: limiting SATA link speed to 1.5 Gbps
[ 26.064083] ata1: found unknown device (class 0)
[ 26.064093] ata1: SATA link down (SStatus 0 SControl 310)
[ 26.225726] ata1: limiting SATA link speed to 1.5 Gbps
[ 26.996086] ata1: found unknown device (class 0)
[ 26.996096] ata1: SATA link down (SStatus 0 SControl 310)
[ 27.155797] ata1: limiting SATA link speed to 1.5 Gbps
[ 27.928089] ata1: found unknown device (class 0)
[ 27.928099] ata1: SATA link down (SStatus 0 SControl 310)
[ 28.085153] ata1: limiting SATA link speed to 1.5 Gbps
[ 28.856093] ata1: found unknown device (class 0)
[ 28.856103] ata1: SATA link down (SStatus 0 SControl 310)
[ 29.016231] ata1: limiting SATA link speed to 1.5 Gbps
[ 29.788095] ata1: found unknown device (class 0)
[ 29.788106] ata1: SATA link down (SStatus 0 SControl 310)
[ 29.946272] ata1: limiting SATA link speed to 1.5 Gbps
[ 30.716097] ata1: found unknown device (class 0)
[ 30.716107] ata1: SATA link down (SStatus 0 SControl 310)
[ 30.875819] ata1: limiting SATA link speed to 1.5 Gbps
[ 31.648100] ata1: found unknown device (class 0)
[ 31.648109] ata1: SATA link down (SStatus 0 SControl 310)
[ 31.806956] ata1: limiting SATA link speed to 1.5 Gbps
[ 32.576104] ata1: found unknown device (class 0)
[ 32.576113] ata1: SATA link down (SStatus 0 SControl 310)
[ 32.737276] ata1: limiting SATA link speed to 1.5 Gbps
[ 33.508106] ata1: found unknown device (class 0)
[ 33.508116] ata1: SATA link down (SStatus 0 SControl 310)
[ 33.666776] ata1: limiting SATA link speed to 1.5 Gbps
[ 34.436126] ata1: found unknown device (class 0)
[ 34.436137] ata1: SATA link down (SStatus 0 SControl 310)
[ 34.598035] ata1: limiting SATA link speed to 1.5 Gbps
[ 35.368111] ata1: found unknown device (class 0)
[ 35.368121] ata1: SATA link down (SStatus 0 SControl 310)
[ 35.528361] ata1: limiting SATA link speed to 1.5 Gbps
[ 36.300115] ata1: found unknown device (class 0)
[ 36.300125] ata1: SATA link down (SStatus 0 SControl 310)
[ 36.457921] ata1: limiting SATA link speed to 1.5 Gbps
[ 38.128120] ata1: found unknown device (class 0)
[ 38.128131] ata1: SATA link down (SStatus 0 SControl 310)
[ 38.287882] ata1: limiting SATA link speed to 1.5 Gbps
[ 39.060127] ata1: found unknown device (class 0)
[ 39.060140] ata1: SATA link down (SStatus 0 SControl 310)
[ 39.219190] ata1: limiting SATA link speed to 1.5 Gbps
[ 39.996143] ata1: found unknown device (class 0)
[ 39.996171] ata1: SATA link down (SStatus 0 SControl 310)
[ 39.996188] ata1: limiting SATA link speed to 1.5 Gbps
[ 40.888129] ata1: found unknown device (class 0)
[ 40.888149] ata1: SATA link down (SStatus 0 SControl 310)
[ 40.888162] ata1: limiting SATA link speed to 1.5 Gbps
[ 41.840130] ata1: found unknown device (class 0)
[ 41.840146] ata1: SATA link down (SStatus 0 SControl 310)
[ 41.840157] ata1: limiting SATA link speed to 1.5 Gbps
[ 42.732134] ata1: found unknown device (class 0)
[ 42.732161] ata1: SATA link down (SStatus 0 SControl 310)
[ 42.732177] ata1: limiting SATA link speed to 1.5 Gbps
[ 43.684135] ata1: found unknown device (class 0)
[ 43.684152] ata1: SATA link down (SStatus 0 SControl 310)
[ 43.684161] ata1: EH pending after 5 tries, giving up
[ 44.912300] systemd[1308]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
dmesg -HT -l err,warn
[Thu Feb 20 01:12:51 2025] genirq: irq_chip rp1_irq_chip did not update eff. affinity mask of irq 101
[Thu Feb 20 01:12:56 2025] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[Thu Feb 20 01:12:56 2025] pispbe 1000880000.pisp_be: Runtime PM usage count underflow!
[Thu Feb 20 01:12:57 2025] rp1-firmware: probe of rp1_firmware failed with error -110
[Thu Feb 20 01:12:57 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:12:57 2025] rp1-pio 1f00178000.pio: error -ENOENT: failed to contact RP1 firmware
[Thu Feb 20 01:12:57 2025] rp1-pio: probe of 1f00178000.pio failed with error -2
[Thu Feb 20 01:12:57 2025] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[Thu Feb 20 01:12:57 2025] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[Thu Feb 20 01:12:58 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:00 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:01 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:02 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:04 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:05 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:06 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:07 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:08 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:09 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:10 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:11 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:12 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:14 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:15 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:16 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:17 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:18 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:19 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:20 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:21 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:22 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:23 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:24 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:25 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:27 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:28 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:29 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:30 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:31 2025] ata1: limiting SATA link speed to 1.5 Gbps
[Thu Feb 20 01:13:32 2025] ata1: EH pending after 5 tries, giving up
[Thu Feb 20 01:13:33 2025] systemd[1308]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
I’ve seen such errors on ROCK 5A with native sata addon, same setup worked perfectly on older release so I guess that something went wrong in system/kernel rather than in hardware.
Flash new sd card and quickly try some releases. Check out lspci for hat and them dmesg as here.
