I’m trying to use this Display in my Rock 4B+ but it turns out, when installing the driver found on the same site, it calls to routines only available for Raspberry OS’es. I’ve tried the same task on Arch, Kali and Debian 11, but i keep getting the same response: Unable to make changes or file not found, which, makes sense as “raspi-config” is not available for Rock.
Does someone found a workaround for this problem? i’d like to not only have exclusive output via the display BUT have the same output on the HDMI port too just in case, i need a bigger display. Hope someone knows the answer or at least, guide me into crafting a new driver. Thanks
Finally i can sit with my board for a few days, so i enabled Waveshare C overlay, and now, touch function works, but display only shows umm… “something weird”
This is the result. Not really sure mine have that chipset?
Edit: Okay, so i followed my instincts, and i tried to fit what I do think its the correct driver, called “TFT35a overlay.dtb” but i think i have a missing step, because rsetup, doesn’t thinks this “driver” is recognizable, maybe i’m leaving something behind, maybe i just only need to change name to fit along with the rest of the files in the folder
fixed it deleting the “new” and going back to the backup
Edit: fb1 is the correct framebuffer as fb0 is HDMI. Remember i’d like to have both outputs at the same time. My project is about a portable PC, so i’d use the display as main, and the HDMI output at certain times i need full control in a desktop
I’ve never tried to display spi lcd and hdmi at the same time before. What happens if you add that fb1 to the original file?
I mean two Screen and two Device.
I don’t really know yet, first i need to fix the display and when i have video there, i will make a few backups and try new stuff, when i learn how these work, i’ll try to improve it
